Question about Pride Jazzy 1113 Power Chair
Lights flash when turned on but no power to the wheels. I've checked all connections but am now at a loss. I need to get this fixed I am sliding around the house on my ****....someone please help. I'm old so please put in easy terms. thank you, Nolan
  • 692 Answers
Nolan Did Medicare pay for your Chair? If they did then they will pay most of the repair. Contact the provider that sold you the chair and ask them to get it fixed for you. Or you can call Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 and ask for a tech to repair your chair Hope this helps
Posted on Oct 18, 2010
Lost power steering, car died, changed battery, and barley made it home. The battery has power, but when you turn the key on the dome light and other lights, radio, windows, etc don't work.
Sounds like the vehicle is not charging you may need a new alternator get the car going with jump leads again and test the voltage at the battery terminals with a DC volt meter expect 13.5-14.5 if you get less than 13.5 your alternator is bad or wiring fault also check the alternator belt is tight.
Apr 27, 2015 | 2005 Volvo S40
Jabra gn9350 base lights are not coming on.
There are a number of steps you can try to fix this issue:
1. Confirm the power supply is plugged in correctly, and the power socket to which it is connected is turned on and receiving power.
2. Remove the battery from the GN9350 headset and ensure the copper contacts on the battery and the headset itself are clean - a quick blow on both parts will be OK. You remove the battery by taking off the earhook or headband, and sliding the speaker section down towards the microphone boom - it will unclick. Reconnect the battery after you've blown on the contacts and re-pair the device as per step 3.
3. Re-pair the headset to the base: ensure the headset is docked in the base. Locate the button with two grey arrows pointing towards each other which is located on the side of the circular base section. Hold this button down for approximately 5 seconds, until you see a blue light flash on the headset itself - you can release the button once the light flashes. The headset is now paired again.
4. If the lights are still not showing up you may have a faulty battery, or a faulty headset/base.
Aug 30, 2012 | Jabra GN9350e Wireless Headset
Fuel gage quit, turn signals canceler quit, fuel pump quit, won't start
With the bike turned off, remove the TSM/TSSM. This is the security module. Make the sure these connections aren't wet. And quit powerwashing your bike!
May 19, 2012 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
Flashing directional lights on console....power loss
we need to know how the flashes repeat starting after the long pause how many flashes then a short pause how many flashes then a long pause and then the code will be repeated
Nov 05, 2011 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
The power loss light kept coming on in our 1985 lebaron. So replaced the battery, still kept losing power, replaced the alternator, still is losing power. What should I be checking next and is it...
the power loss light has nothing to do with the alternator, the power loss light is part of the on-board computer system it is the equivalent of the check engine light on newer cars it is on because one of the sensors is not working on the car.
this is how to retrieve the code that is turning on the light.
turn the key on ( do not crank the engine ) turn the key off, turn the key on, turn the key off, turn the key on. ( never crank the engine ) this all has to be done in les then 10 seconds so to re-cap key on, off,on,off, on.
the power loss light will start flashing. all codes are 2 digit, for example a code will look like this.
flash,flash, pause (about 1 second), flash, flash,flash this code would be a 23 , the first two flashes would be a 2 the pause is the separator the next 3 flashes are a 3 so the code is 23, i hope you under stand.
after you get the code let me know what it is and i will look it up for you....good luck
Mar 21, 2011 | 1985 Chrysler LeBaron
When I engage the four wheel drive the transfer case shifts over like it should but it seems like the front differential is not fully locking. with the trucks on jackstands the front wheels will turn but...
there was a tsb on loss of 4x4 electrical A flashing 4X4 lamp and/or a intermittent or loss of power windows, interior lights, rear wiper, or 4x4 system. the loss of 4x4 system was from a module.
Feb 03, 2011 | 1998 GMC Jimmy
Speedometer quit, Drive 4 light started flashing, check engine light now on, slight power loss when accelerating
check your wheel speed sensors. and vehicle speed sensor on the transmission
drive 4 uses it to sense slip in the front/rear wheels.
check engine light on because it needs to know vehicle speed to shift properly.
no speedometer because it turns the voltage into a signal to the gauge
Oct 06, 2010 | 1995 Honda Accord
Red light keeps flashing wont turn on...is this going to be expensive to fix
I have the same problem, did you find a fix? I am going to replace the fuses on the power board to see if they work. I ordered some on Ebay and found the repair instructions on Youtube . I am hoping this works. I have seen this problem is common with all power loss, but I have a red flashing light still and power loss.
Oct 06, 2010 | Samsung FPT5084 50 in. Plasma HDTV
Lights flash when opening power doors
when you open the power sliding doors the turn signal lights are supposed to flash. are there other lights that flash?
Dec 29, 2008 | 2005 Dodge Caravan
Pride Jazzy 1113 Power Chair Logo
65 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
