Your printer should have been packaged with a USB cable regardless of whether it is a wireless or wired printer. Plug the cable into your printer and your computer's USB port. The direct linking should trigger your computer to recognize the printer and start up the software needed to complete the installation.
How To Install Nokia MTK USB Serial Port Driver: Step 1: First Download (WinRAR/ 7-Zip) Software And Install On Your Computer. Step 2: Download Nokia MTK USB Serial Port Driver, Then Right Click And Extract Files On Your Computer. Step 3: Open Nokia MTK USB Serial Port Driver Folder. Step 4: Now Select (Nokia MTK USB Serial Port Driver.exe) And Right Click To Select Run As Administrator. Step 5: And Then Next- Next- Finish. Step 6: Then Restart Your Computer. Step 7: Now Your Nokia MTK USB Serial Port Driver Install Complete.
Next, open device manager (Click Start Menu and type in "Device Manager", right click and run as administrator). Then find your device in the list, and uninstall it. Immediately, unplug the wireless USB from the computer. Now, restart your computer with the USB unplugged. Insert your driver disk and install the driver, when prompted plug the wireless USB back into the computer. Hope this helps.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.
Follow the steps below to install Windows® 98 or Windows® ME driver
5.1 Turn on the power of computer and make sure the USB port is enabled and can
working properly.
5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive.
Select “Install Products - USB-SERIAL ADAPTER - Install”.
5.3 Select the “Next” to install.
Follow the steps below to install Windows® 2000 driver
6.1 Turn on the power of computer and make sure the USB port is enabled and can
working properly.
6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive.
6.3 Select the “Next” to install.
Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.
Follow the steps below to install Windows® XP driver
7.1 Turn on the power of computer and make sure the USB port is enabled and can
working properly.
7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive.
7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X)
8.1.1 Power on your computer and make sure that USB port is enabled and working
properly.
8.1.2 Insert the USB adapter software driver into CD-ROM driver.
8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on
"PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303
driver" folder in the desktop.
8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto
install, you may change the driver directory that you want to install.
8.1.5 System will demand restart computer.
8.1.6 Plug in the USB-Serial adapter into USB port.
8.1.7 To make sure that your computer can use the device, you have check the
"Apple System Profile"-"Device and Volumes".
It will show the USB Device.It will show in USB port "USB-Serial Controller".
8.2 Driver Installation (MAC OS 8&9)
8.2.1 Power on your computer and make sure that USB port is enabled and working
properly.
8.2.2 Insert the USB adapter software driver into CD-ROM driver.
8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on
"PL2303_OS9_v136b1.hqx",it will auto run the program and appear
"ProlificUSBSerial" file.
8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension".
8.2.5 Plug in the USB-Serial adapter into USB port.
8.2.6 To make sure that your computer can use the device, you have check the
Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
your scanner is ok. But there is communication problem from computer to scanner . For that Check your usb cxable and usb port of computer working fine. Try in another usb port. If you have other port like parallel port then check it. Check drivers of scanner are instaled proeprly. Ig already installed then uninstall it and install again. Also uninstall all usb drivers then restart the computer then it automatic install usb drivers . you can uninstall usb drivers from computer with device manager. Press windows key + Pause break key to see system proeprty then go to hardware then you see device manager then uninstall all usb drivers.
go to my computer property then hardware then device manager then
uninstall usb drivers then right click any driver and clik on scan for
hardware then it install automatic usb drivers. then restart computer then connect pen drive to computer then check if still face problem try all usb port of computer. also check your usb port of computer are working fine.
Thanks for using fixya. Please rate solution if it helps you.
