Question about Lexmark Office Equipment & Supplies
My printer keeps saying Cover Open and won't let me do anything else
    Novelist:
  • 85 Answers
Hi All printers have a protruding piece of plastic on the cover / lid, when out of place it tells the printer the cover is open
When you close lid it is inserted into main frame which tells the printer that the lid is closed.
Look for this it may be damaged. If so roll a small piece of paper and insert ito the recepticle hole.
It will trick printer that the lid is now closed.
You will need to remove it each time you need to change inks etc...
Good Luck!
Tinteiros (Ebay)
Posted on Jun 02, 2008
Keeps saying printer is "offline", but still
Contact the printer customer service, they may need to install an updated driver (especially if the printer is a Lexmark).
Aug 24, 2011 | Apple MacBook Pro MB991LL/A 13.3-Inch...
Toner light keeps flashing and printer won't print - even though it has a brand new cartridge.
Please try the following steps.
  1. Turn the printer OFF.
  2. Reseat the cartridge.
  3. Switch the printer ON.
Or
  1. Open the top cover.
  3. Close the top cover.
Jul 02, 2011 | Lexmark E232 Laser Printer
I changed my ink but it wont let me print it keeps saying i need to change my ink why?
What is the version of your ink cartridge? It could be that it's not seated properly in the cartridge carrier. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, open the printer cover and reinsert one cartridge first. Close the cover. If no error, open the printer cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You could also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark Z2300 InkJet Printer
Printer keep saying cover is open and cant find
====.> continued from an earlier answer that seemed to close up too soon, before I finished typing my response.
... and the cover appears to the printer to be open. If you can clean this photo-ectric sensror, it will tell the printer that the cover is actually closed, as it should, and the printer will return to printing as it should do.
Clean all photoelectronic sensors, to ensure that they are all going to respond as they should, and your printer will then work fine.
-a.
Dec 06, 2009 | Dell Office Equipment & Supplies
Lexmark P3150 says cover is open
May be the cartridge not fitted properly.
Also try to unplug the printer during PC on. and then replug it.
Try to power off printer, restart PC and disconnect USB, then connect after restart PC.
Let me know if you need further help.
Oct 04, 2008 | Lexmark P3150 All-In-One InkJet Printer
LEXMARK 3470 COVER OPEN
there is a switch actuator on these cover try to see if you can find any piece of tab that actuate these switches, unless the cover is really closed ensure that it is fully flat
cheers
Sep 17, 2008 | Lexmark X3470 All-In-One InkJet Printer
The Error says "Cover Open Front" but it is not open
Most printers have a plastic pin on all of the covers that pushes a switch when it is closed. This then sends a signal to the printer telling it "I'm closed".
Probably the pin is broken off (quite by accident I'm sure). A solution is to push a piece of paper in the hole where the pin is, closing the switch, to fool the printer into thinking that the cover is closed. You can try this by pushing a pen point into the hole to see if the message goes out. (Don't forget to remove the paper when you open the cover. The switch is there to keep things out of the mechanism while it is running. May not hurt you but will damage the printer mechanics irreparably.)
Anything else is an error with the printer software and processor and can't be fixed easily.
Sep 02, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Cover open error
There is a latch that preses a small switch when you close the cover (look for this) to indicate that it it close if it is broken you can tweek it using a toothpick or anything that may press the switch temporarily this may alow it to work as long as the switch stays down.
May 28, 2008 | Lexmark X3480 All-In-One Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
57 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
