Question about Polycom 2200-08681-001 Microphone
The external microphone (P/N 2201-20250-002) has stopped working. Our connection cord runs underground to the Polycom system. Anyway to check if it's the unit or the connection?
3 Suggested Answers
ajaybcd
  • 7 Answers
SOURCE: I have polycom 7000 with
Verify the uplink / download bandwidthon the broadband link.Broadband link do not have symmetrical upstream/downstream speeds. Perform test to verify.
Try non-peak hrs.
Check if latency is consistent.
Posted on Oct 14, 2010
SOURCE: SoundStation VTX 1000: VTX 1000: can I use my existing Polycom extended microphones...
mic solution
Posted on Dec 13, 2010
Does the Nortel Norstar 2501-03308-001 accomodate external microphones?
No sorry it does not.
For larger board rooms you need an Analog Polycom like the SoundStation2 Expanded w/mics.
It will require an ATA on the phone system to covert digital to analog.
Nov 27, 2012 | Lands Phones
My VSX 7000S does not recognize the microphone. It is connected to VSX\r\ncamera by the brown RJ11 cable with ferrite end to the camera but no sound is picked up and system status indicates "no...
You need to go into the audio settings via
Admin Settings
Audio Settings
and make sure Enable Polycom Microphone is checked off.
Reboot and see if your microphone is recognized.
Jan 13, 2011 | Polycom VSX7000 Videoconferencing System...
Polycom soundstationex
this unit requires POTS (plain old telephone service) .. thats the normal phone jack that you would find in your home ..the base station is connected to that via a standard phone cord .. if you have digital phone service (many businesses) then you would need a digital adapter (availible from polycom) .. or you can connect it to most Cell phones via a standard 2.5mm sterio (headset) cable.. (male/male)
you can view these things here
http://www.officedirectinc.com/Phones/poly2w.htm
the "EX" in your part number indicates that its expandable . you can add up to two wireless microphones
Nov 27, 2009 | Polycom SoundStation2W EX (220007800102)...
Polycom Sound station - help it won't work!
what line have you connected to the polycom? you will need to connect a single line circuit line.
Apr 06, 2009 | Polycom SoundStation
MWI doesn't work on Polycom SE-225
The issue isn't exactly resolved. This appears to be due to an incompatibility of the Polycom Se-225 on our Meridian 1 phone system. But Converse handsets with MWI work fine. I have a partial solution by disabling the lamp (LPD on class-of-service), while leaving MWA setting. This allows the interrupted dial-tone when the user lifts the handset.
Dec 09, 2008 | Polycom SoundPoint Pro SE-225 Corded Phone
Conference call with a Polycom SoundStation EX
The conferencing capability to bridge 2 (or more) external stations comes from the telephone equipment/service that you have purchased. Either you are behind a PABX or Electronic KSU, which provides multiple phone service to your office, or you purchase conferencing capability from your local telephone provider (Verizon, AT&T, etc). In either case, the way to initiate a conference call would be the same as when you would have a desktop/office phone and establish a conference/bridged call to external parties. Usually this occurs by having one party on the line, flashing the disconnect button momentarily, getting a new dial tone, dialing and connecting to a second party, then flashing the disconnect button again, which signals the equipment to bridge those two calls to your station.  On the SoundStation EX there is a Flash button that provides that capability of momentarily flashing the disconnect button.  Try and see if that works. If not, then you will need to make arrangements to purchase the external equipment or service from your provider.  If you have the PABX or electronic KSU, it may also be a configuration option that you will need to have your support person for your telephone system, activate for that station connected to the SoundStation EX. Hope that helps.
Oct 22, 2007 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
No sound transmitting from Soundstation EX wireless mic # 2201-00699-002
confirm that you select aux input in your soundstation2.-if your problem excit change audio cord between receiver output and the aux.
Oct 17, 2007 | Polycom SoundStation EX (expandable)...
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
Polycom 2200-08681-001 Microphone Logo
427 people viewed this question
Top Polycom Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Polycom Audio Player and Recorder Expert? Answer questions, earn points and help others
