Question about HP LaserJet 5p Printer
Printer is sealing envelopes and fuser is getting very hot, how can you change fuser setting on this model printer
    President:
  • 261 Answers
Hi
before change
1 - Do service
2 - check the sensor the check fusing temprature
sometimes cleaning the sensor solve this problems
good luck
Posted on Oct 14, 2010
WHAT IS THE THUMPING NOISE WHEN PRINTING?
Two possibilities I can provide:
1. The fuser pressure roller is out of round and the noise is the flat spot hitting the hot roller on every rotation.
2. These printers have an envelope mode that activates a solenoid in the fuser when printing envelopes to force air out of an envelope.
If it makes the noise constantly then it is the fuser. If only as the page is exiting then it is the envelope mode.
Oct 09, 2014 | Lexmark T634 Laser Printer
On anything other than plain printer paper, the ink tends to rub off the printed page - really a problem with labels and envelopes. I have tried changing the printer settings for these items, but it does...
You may need a shop to increase the fuser temperature. You also may just need a new fuser. In printing preferences you need to make sure you're telling the printer you're using envelopes or labels. When the toner rubs off, the fuser is just not hot enough.
Nov 05, 2009 | HP LaserJet P2015 Printer
The Fuser is getting HOT. Error code 50.9 appears on our HP 3600N
i have a machine just like that it is normal that the fuser gets hot is a laser machine, and the part with the envelope the tracks for the paper might be worn out you said that you use it a lot check that or clean the tracks
May 26, 2009 | HP Color LaserJet 2600n Printer
Ink flakes off envelopes. No problems with sheets of laser paper.
High burnier:
Try these settings.
FUSER MODES
PLAIN
PREPRINTED
LETTERHEAD
TRANSPARENCY
PREPUNCHED
LABELS
BOND
RECYCLED
COLOR
CARDSTOCK>164 G/M2
ROUGH
[Paper Type]=
NORMAL
LOW
HIGH1
HIGH2
ENVELOPE
RESTORE MODES
Use this item to configures the fuser mode associated
with each media type.
Change the fuser mode only if you are experiencing
problems printing on certain types of media. After you
select a type of paper, you can select a fuser mode
that is available for that type. The available selections
might include some or all of the following modes:
NORMAL: Used for most types of paper.
HIGH 1: Used for rough paper.
LOW: Used for transparencies.
HIGH 2: Used for paper that has a special or rough
finish.
The default fuser mode is NORMAL for all print media
types except transparencies (LOW), and rough paper
(HIGH 1).
CAUTION
Do not change the fuser mode for transparencies.
Failure to use the LOW setting while printing
transparencies can result in permanent damage to
the printer and fuser. Always select Transparencies
as the Type in the printer driver and set the tray type
at the printer control panel to TRANSPARENCY.
When selected, RESTORE MODES resets the fuser mode
for each media type back to its default setting.
Hope this helps
May 24, 2009 | HP LaserJet 4300n Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Envelopes get wrinkled while printing
The problem is likely the envelopes.
OK, I'll explain what is happening first.
If you think about it this way: The envelope has air in it, not alot but some, as it moves into the fuser "the heater" the air heats up and expands. If the envelope does not have enough "leaks" for the hot air to escape it creates a bubble in the envelope that gets squashed as it moves thru the fuser giving you the wrinkles.
Does that make sense?
Most envelopes (if you have ever looked closlely at them) have small openings in the corners that let the air escape.
Sometimes the opening are to small or not there at all.
Yes the heat can also seal the envelope. Usually not if you are using laser specific envelopes.
Now that was a long winded way of saying try new envelopes made for laser printers.
Hope this helps
Feb 20, 2009 | HP LaserJet 3600n Printer
Envelopes
Make sure the paper type for the tray from which you print envelope is set to Envelope. If the printer doesn't know that an envelope is being printed, it will not turn on the "Envelope Enhance" feature. The Envelope Enhance feature pumps air out of the envelope before it enters the fuser and can prevent creasing in the envelope. However, keep in mind that any envelopes larger than a US Size 10 will most likely crinkle, with or without the Envelope Enhance
Dec 19, 2008 | Lexmark T644 Laser Printer
Envelope Printing
There is a way I believe to release the tension on the fuser for envelopes.
Check the control panel on this printer, and if you are using the Manual Paper Tray, set the settings to envelope.
The fuser will ease up the tension in the fuser, and pass the envelope through at a different speed (I think speeds it up)
So that you do not have that problem.
Is it humid where you live?
Aug 02, 2008 | HP LaserJet 8500 Color Printer
Ink is wiping off my postcards I printed
Is it just with your envelopes? or all your pages that you print?
Usually, when a Laser printer "Smears" it means that the FUSER is bad.
If you do a websearch for "LJ1300 fuser" You should be able to find them for sale. or, check your local Office Supply Store.
Sometimes envelopes are TOO THICK for the fuser to handle at the speed that the printer sends them through, and the toner doesn't have enough time to bond to the envelope. There may be an envelope setting with your printers software, or, you might want to look at the back of the printer.
The door will open. Looking for blue or green or orange or yellow tabs with arrows on them, or paddlock icons. Maybe even an envelope icon. Sometimes you have relieve the fuser tension for envelopes.
If you still have your HP Documentation, check that.
HP has pretty good support on their site.
Q1334A Is the TRUE Model Number of your printer,
Its on the back of your printer.
I hope this helps you.
Jun 05, 2008 | HP LaserJet 1300 Printer
PRINT RUBS OFF
When printing envelopes ensure you set paper/media type to Envelopes, and feed via tray 1/bypass . Paper type setting sets correct fuser temp, the fuser is the hot bit at the rear that "melts" the image into the paper.
If paper type is set correctly then I recommend you change the fuser unit.
Ensure envelopes are standard type. ie you are printing on paper envelopes
Feb 11, 2008 | HP LaserJet 5p Printer
HP LaserJet 5p Printer Logo
301 people viewed this question
Seeker5211
Seeker5211
