Question about Hasbro Furreal Kitty Cat
Is there a reset button on this cat? I put new batteries in and it still will not work. Thanks!
Is there a reset button on a Merit Pioneer 10 scooter
You had better recheck your connections because the batteries are polarity reversed
Mar 20, 2017 | Cars & Trucks
Cat knocked my digital camera off the desk now the screen is blue
Try reseting your camera
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
  4. if you dont have a reset button try the manul reset below
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. hope this helps
Aug 02, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Furreal kitty white not working
Sounds like you need to reset it. If you need help finding the reset button, go to www.hasbro.com and click on Customer Service, then click on Instructions and find your toy to pull up the PDF file of the instructions. Hope that helps!
Jan 19, 2009 | Hasbro Furreal Kitty Cat
Wii fit board wont sync
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
Dec 29, 2008 | Nintendo Wii Console
Remote won't work
reset the default setting go to menu button and manualy do this.....
Jun 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
My remote does not work
Reset remote. If universal remote, put on dvd mode.
  • If your remote has a Reset button, take out the batteries and press the Reset button for 2 or 3 seconds. Re-inset the batteries and try using the remote again.
  • Note: Many remotes have a small hole marked Reset instead of a raised Reset button. To activate the Reset function, you need to push a thin, rigid wire (for example, a straightened paper clip) into the hole to "press" the Reset button. Also, the Reset button or Reset hole may be located under a sliding cover on the lower section of the remote.
  • Remove the batteries and hold down the POWER button for 1 minute. Insert fresh batteries and try using the remote control again.
  • If this does not solve your problem, remove the batteries again and press and release each button on the remote control once, then repeat. Re-insert the batteries and try operating your remote again.
Otherwise you need a new remote. If under warranty call manufacture to see about getting one free of charge. They can also help you purchase a new one if not under warranty.
Jun 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Craftsman remote -- new battery installed..
close the garage door, press the lock button so that's it's blinking, press the red reset button on the craftsman, then press the remote.... that should work
Feb 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
YB 300 PE
The reset button didn't work for me.
Mar 03, 2007 | Grundig YB 300PE AM/FM/SW Radio
Hasbro Furreal Kitty Cat Logo
119 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
