Question about Frigidaire FER641FS Electric Dryer
Dryer runs, but doesnt heat up. already changed the fuses, still no heat
  • Frigidaire Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Posted on Oct 15, 2010
My dryer will not heat & I've already changed both non resettable fuses & it is not the heating element.
Did you check the voltage to the dryer?? Most electric dryers run off 240 volts for heat but if one side blows a fuse or half a breaker goes bad, you could still have it run the motors on 120 volts but get no heat.
Mar 02, 2015 | Dryers
Top thermastat has no voltage?
Are you getting 240v to the element ? If not it may be the timer , the centrifugal switch on the motor or a fuse . start by testing continuity in t he fuse then test timer .
GOOD LUCK
APPLIANCES R'EN
Dec 08, 2013 | Kenmore Dryers
The drum rotates and blows air, but it doesnt blow hot air. I already changed out the thermal fuse.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 01, 2011 | Dryers
Dryer runs but doesnt get hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 12, 2010 | Kenmore 800 7983 Dryer
My Whirlpool Imperial electric dryer runs but there is no heat. I changed thermal fuse already.
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 06, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Air not heating up in whirlpool dryer
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 25, 2009 | Whirlpool LER8648P Electric Dryer
My kenmore 70 series dryer isn't drying - changed the heating element, changed the thermal fuse, and the high limit thermostat. Lint is cleaned and the motor is running.
Are you getting any heat at all? Did you change the thermal cut-off which is mounted near the top of the heater box? This is the only other piece in the heating circuit. If you changed it already you could have problem in the timer or in motor. There is a switch in the motor that controls heat also.
May 26, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
My dryer runs but doesnt heat
most common cause of no heat to either electric or gas dryers is failure of the thermal fuse
followed (for gas, this is posted to gas dryers) by failure of the flame sensor or igniter
all of which are easily accessible
once the cover is opened as described in any of the 'changing belt' threads or in Jokso's excellent howto articles
Oct 30, 2008 | Kenmore 73932 Gas Dryer
Frigidaire FER641FS Electric Dryer Logo
57 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
