Question about Maytag Refrigerators
Maytag refrigerator My freezer keeps getting ice built up on the floor of the freezer (it's a side by side) and if I don't chip it away it will overflow water onto the floor. I turned the water off to the fridge and it still keeps doing it. I know the water is off to it because water won't come out of the water on the door. Where could the water be coming from? What could be wrong?
    Habit-Forming:
  • 111 Answers
It may not be a water problem, it may be an air leak.
If there is something that is keeping the door from total closing, ice will build up from moisture.
check the gasket around the freezer door, or see if there is something that is keeping it from closeing completely.
Posted on Jun 02, 2008
I have water leaking under freezer side of door. I turned the ice maker off, turned off the water to the fridge, cleaned out the ice behind the panels, and put it all back together. Every couple of days I...
Hi, The drain hole is plugged with debris or ice...
Just had to thaw my own out tonight, it was doing the same thing... Take the bottom draw out and maybe the bottom shelf and then you will see the ice buidup in the back and on the floor... Thaw it out and make sure the drain hole is open... then you will be okay again...
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 25, 2011 | Maytag MSD2651 HE Side by Side...
Hi i have it a maytag admiral side by side and it keeps dumping water on floor from front can you suggest anything
Check the freezer floor to see if there is a sheet of ice built up on it. If so you have a clogged drain further back and water is overflowing instead of going down the drain when it goes into defrost. Remove the bottom bin, clear the ice and further back clear the ice from the drain hole using hot water or a screw driver, but be careful if you do that. Once water flows freely down the hole your problem is fixed. If there is no ice in the freezer floor check the waterline that runs to the dispenser which is also located on the front left side if your facing the machine. You'll have to pull the kick plate of do so, but if thats the problem you'll notice water every time you get water from the door.
Nov 02, 2010 | Maytag Refrigerators
Ice build up in bottom of freezer and leaking out on the floor
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 13, 2010 | Maytag MZD2766GES Side by Side...
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to...
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
Ice built up floor of freezer compartment. water on floor
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jun 09, 2010 | Maytag MZD2766GES Side by Side...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag Side By Side Problem
Check and make sure the drain pan under the refrigerator is in position and the drain hose is in the pan. If it misses the pan it will put water on the floor.
May 31, 2008 | Maytag MSD2456G Side by Side Refrigerator
Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Dec 16, 2007 | Refrigerators
We had the same problem; soon your other side of the fridge will start to not cool as well. A circuit board had to be replaced per the Sears repair guy. Cost was about $270 but our icemaker doesn't work so well still. The ice cubes are hollow and it doesn't churn as well.
Aug 16, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
83 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
