Question about Marantz CD5003 CD Player
The CD tray door on my marantz cd5003 has stopped working properly. It opens halfway and then closes. No other functions work.
2 Suggested Answers
doron_c21
  • 387 Answers
SOURCE: Open/close door on Marantz CD5003
Hi
try to open the top cover and look what is causing the tray to stop it could be that there is a disc stuck or maybe the rubber belt from the motor is dry and canot puse the tray
hope it will help
Posted on Oct 22, 2010
How can i open my cd drive to insert my cd?
If the button on the drive won't pop open the drive, then you need to find out what is causing it to stick closed. Most drives have a tiny hole on the door so you can push a paper clip in it to open the door.
Jun 17, 2015 | Computers & Internet
Marantz PMD 350 CD player/Cassette deck
Well if you want to DIY you should open the coves, spay some oil on the mechanics and ensure they are running smoothly, if you spray grease on lens you will damage it, be careful.
Jun 01, 2008 | Audio Players & Recorders
Philips CD changer, tray does not work
Five-disk "carousel" changers are prone to failure with age.
Aug 20, 2014 | Philips CDC775 5-Disc CD Changer
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Mar 31, 2014 | Marantz Audio Players & Recorders
After reading toc of my Marant zcd5003 the display is "error" seeking help to find out the cause
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
follow the steps and fix it.
God bless you
May 27, 2013 | Marantz CD5003 CD Player
CD-72 Marantz CD Player disc tray is stuck in the shut position.
You might have to open the player and see why. remember to unplug till you need to see if you can get it to work or not.
Sep 06, 2012 | Audio Players & Recorders
Marantz CD5003 CD Player pauses
Not may be! It is. Check and replace it.
Aug 10, 2012 | Marantz CD5003 CD Player
Cd tray won't stay open--when you press the "open" button, it opens but then closes again immediately.
It has a misaligned loading mechanism. I have dealt with this kind of problem before. What is happening is that before the tray have a chance to open all the way it gets stuck and gets pulled back in.
May 24, 2011 | Marantz CD5001 CD Player
DR6000 display "open"
you may need to replace the whole mechanism as i've had quite a few philips and marantz cd recorders with the same mechanism with exactly the same problem. when you press open/close it will display open or close with no sign of life from the player. this turned out to be a faulty laser unit and the PCB which is underneath the mechanism seems to go the same way which i found out later when i replaced the laser unit. the recorder worked for around 5 minutes then the laser started moving erratically but then would work again for 5 minutes after switching it off & on again. i cured the fault by replacing the PCB aswell. hope this helps?
Aug 24, 2009 | Marantz DR-6000 CD Player
Numark CD mix 3 right cd door seldom opens
Defective load belt or defect in laser assembly
Sep 11, 2008 | Audio Players & Recorders
Marantz CD5003 CD Player Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
