Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The oven won't heat. Can I relight something?
    Problem Solver:
  • 5 Answers
Does your oven have a pilot light or an ignitor (pilotless)? If it has an ignitor, it probably needs replacing. I can't help you if it does have a pilot light. Do you hear clicking when you turn your burners on, if yes, that means you have an ignitor system.
Posted on Oct 16, 2010
The oven comes on an heats up to temperature , after a short while the oven no longer continues to heat. The contol panel shows on in bake mode , but the oven continues to cool.
Hello Brian;
You did not provide any information on the unit that you have. After you open the oven door there is a metal label on the face of the oven. Send that to me so I can see what you have.
1.) Some ovens have a single or dual broiler thermocouple.
2.) Some ovens have a separate control board for the oven.
3.) Some ovens have a Infinite switch.
Mar 21, 2015 | Kitchen Ranges
Should the oven glow plug stay lit when oven is lit
Yes. It's what relights the flame when the thermostat calls for heat after it has preheated. The glow bar operates all the time the oven is in.
Sep 24, 2014 | Ovens
WFG371LVS
The oven electronic ignition is bad, very common, to replace remove oven door and the grate shelf, then unscrew bottom panel inside oven , you will see the ignition device towards the back unscrew it and unplug the the electrical plug to remove and replace it. I found them cheaper on line, like Sears parts center, it takes about 15 minutes to change out.
Mar 26, 2013 | Whirlpool GS563LXSS - stainless Steel Gas...
Turn on oven - but no gas. Is there a way to relight it?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 21, 2011 | Maytag CWG3100A Gas Single Oven
How to relight a kenmore oven it wont relight
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 13, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Moved range from home to cabin. Now when trying to use oven it won't heat. By turning on one burner on the top the range will heat. If we turn off the burner on the top the oven will continue to heat....
If one of your burner heating elements works only intermittently, it's probably because of worn or bad contacts in the receptacle that the element plugs into. On most electric ranges, you can remove the element by lifting it up several inches and firmly pulling it away from its attachment (receptacle). Read your owner's manual to learn the correct technique for your range. If, after removing the element, you see that the ends of the element that were plugged in are pitted, corroded, burned, scarred, or rusted, replace both the element and the receptacle.
Take care.
Sep 04, 2010 | KitchenAid KGST307 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
105 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
