Hello! I'm trying to find IC101 chip, for my Sony HI-FI system. Control volume doesn't work. I'don't know where to order it? This HI-FI is not very new :( Thank you! Best regards, Sabina
SOURCE: MY LCD SCREEN DOESN´T WORK GOOD
My LCD would go white...I fixed the camera myself as follows:
1. Hold camera firmly in left hand
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
It worked, now the LCD is working again for free.
Guess I don't need to pay Sony $111.00 for repair service.
Posted on Feb 23, 2008
cnavarro
  • 2460 Answers
SOURCE: Panasonic phone KX - T7630 - memory
Of course it's possible. Maybe the PROG softkey is a start. That an a manual.....
Carl
Posted on Aug 23, 2008
SOURCE: problem with my webcamera
where can i find web cam and display drivers for VGN-CR11GH
Posted on Nov 09, 2008
  • 9 Answers
SOURCE: Cruise control
The cruise control button may need to be replaced, as is common on these cars.
One websit i reccomend it vwvortex.com you click the forums button and sign up and navigate to the correct forum and post about what your looking for.
Posted on Nov 19, 2008
SOURCE: remote control for technics hi-fi
I had the same system... still have the remote if you're interested in it?
Regards, Gary.
Posted on Mar 25, 2009
Factory reset sony mhc-6700
I don't think that will cure the problem. Volume controls these days are done by an IC. If it fails it can cause the volume to go up on one channel and not on the other. If you trace the wiring back from the volume control you will eventually run into the chip. I would have thought that the two channels will go into one chip and not two separate chips for each channel, but it depends on how complex the system is. If you are lucky the PCB will even tell you that the area is tone and volume control.
Feb 27, 2016 | Sony Audio Players & Recorders
Sony Mini Hi-Fi Systwm shuts down at high volumes
You need to have the fan in the check,possibly its not working anylonger
Jan 22, 2014 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Volume decreases during use
Very simple. It is not a defective unit. Simply a matter of volume attenuation, hold the "function" and "grove"keys for aprox 5 seconds until a message saying vac off appears. Problem solved. Resets itself eveytime the unit is turned off .
enjoy!!!
Nov 16, 2013 | Sony RDH-GTK1i Hi-Fi Music System
Volume control on rt2370 rca remote doesn't work.
Hi there
I would try going into VOLUME through the MENU and find volume there and set it accordingly.
good luck
Kolbrun
Mar 26, 2012 | RCA Audio Players & Recorders
Cant get sound
This can often be as simple as the speakers being unplugged, plugged into the wrong jacks, or powered off, so don't overlook the obvious and check to be sure. Also check the volume controls in Windows or your application to see that they are turned up and not muted. When you are sure the volume is turned up, the speakers have power and are plugged in, and the speaker configuration is correctly identified in Windows (some audio hardware uses a proprietary mixer control for this job), you need to verify whether the problem is with the speakers or the sound card. Connect different known-good speakers and see whether they work. If they don't, the issue is in the sound card-possibly the configuration of the card is incorrect or the card itself is defective. The first thing to try is clearing the ESCD in the BIOS Setup. This essentially forces the plug-and-play routines to reconfigure the system, which can resolve any conflicts. If this doesn't help, try removing and reinstalling the sound card drivers. Finally, if that doesn't help, physically remove and replace the card from the system. You might try replacing it first in the same slot and then in a different slot because timing issues can sometimes exist from one slot to the next. If that doesn't work, you must try replacing the card. If the sound "card" really isn't a card but is integrated into the motherboard, first try the ESCD reset and driver re installation. Then, if that doesn't work, you have to try disabling the integrated sound and perhaps installing a replacement card.
I hope one of these solutions help.
Sep 05, 2011 | Systemax AOL Optimized PC (100607) PC...
I was accidently connected the subwoofer ,when my sony hi-fi volume level is 30 (maximum)...and then it automatically shutdown..after that,it started to show PUSH POWER ,PROTECT..
Hi, I believe the sub is the wrong kind for your system. It should be a selfpowered sub one that you plug in to AC power and then connect to Hi/fi. You could do some damage to your system if you carry on with that. Good luck
Jul 18, 2011 | Sony Multi-System Mini Hi-Fi system /DVD...
My sony hi-fi system indicates mechanicl error whe i try to play cd,what can i do?
Wow, mine has the same problem - let me know if you figured out how to fix it. <!-- from fixya rte -->
Apr 13, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
The speakers on my tv are done in , how can i get sound through anything else can i us a hi fi system
Your TV must have an adapter for output where you can connect the
cord to the input of your hi-fi system. Yes, you can use it, and control
the sound from your TV and Hi-fi. First, you must set your TV volume
to low position. Then, adjust the volume further at your Hi-fi to a
comfortable level. Let us know thru the e-mail and vote for our solution.
Sep 25, 2009 | Samsung P42H 42 in TV
I need a part # for the volume controle on an Aiwa
The "volume control" on your Aiwa is in fact what is called an "encoder". These can fail. They work in concert with the microprocessor to control the electronic volume control IC. Yes this part can be replaced. Try calling Sony with your model number and request the part number for the volume encoder. They should be able to help.
Dan
Aug 24, 2009 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
JVC MXJ30 Compact Hi-Fi
Spares from JVC? Where's the cheapest remote? Where's the cheapest Service manual?
Mar 09, 2009 | JVC MX-J30 CD Shelf System
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Electro Med Services...
