Question about FAIP 2100psi 2gpm Faip Power Pressure Washer Pump Only
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Posted on Oct 15, 2010
What kind of pump oil
What you have is a generic pump from china more than likely. Its built along the line of a FAIP pump. They arent supposed to have the oil changed in them at all. Most are sealed pumps but may have a plastic plug in it. If you must replace the oil then I would suggest Pressure washer parts catalog quick links Pressure Washers High Pressure... and get this item 4.5 OZ. AR64545 OIL FOR AXIAL PUMPS. It is recommended for pumps built similarly but not for your specific pump. But it should work. Good luck. W
Feb 21, 2015 | Simpson MSV3025-S Megashot 3000 PSI Honda...
Location of pump oil input valve
Hi
Im surprised that this model pump has a oil refill. Most pumps of this size arent refillable. This looks to be a pump made by FAIP. Its an ok pump but I would recommend using it until it fails and then replace with an AR RMW pump. Much easier to get parts for. Here is a diagram of your pump...The oil refill plug is on the side of the pump...that is located under your engine. You want to get the recommended oil for your pump. Most pump oils are 30 weight non-detergent but these small pumps take an oil specific to only them. So follow your specs...your diagram is here http www searspartsdirect com Craftsman Power washer Parts Model 580752330...
and your manual is here 580752330 CRAFTSMAN PRESSURE WASHER Manual
Hope this helps
Sep 20, 2014 | Craftsman Garden
How much oil in berlina engine
engine oil refill quanity
3.8 v6 quanity required 4.8L
5ltr v8= 5.1litrees
GEN 3 V8= aprrox 5.0l
Jun 24, 2014 | 1999 Holden VT
How much oil should be charg in 1.5 system
The oil charge has less to do with system size & more to do with size & type of compressor being used. most comp. manufactures will list oil type & quanity on the tag located on the body of the compressor. very very rare to have to mess with oil charge on a central a/c unit unless tubing runs are extremly longer than 50 feet & needs to be added at install of unit by recommended allowances of units manufacturer.
Apr 23, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
What is the oil capacity of the EJ-DE engine found in the 2000 Daihatsu Cuore?
Many Auto Parts stores have the computer that specify oil weight, quanity needed and viscosity type and filter type and location.
Mar 20, 2011 | Daihatsu Charade Cars & Trucks
When adding SAE 30 oil to new pw, do we add to the pump reservoir only or do we also add to the two oil inlets on either side of the engine housing?
From what i've read in the manual you need to fill both the pump and the motor. The pump itself will have a dipstick, the motor gets filled to the top. If the motor has two inlets one should fill up when you pour in the other side. Most briggs had two motor oil inlets so the motor could be used on several types of equipment. The pump itself should use about 9.6 oz
Mar 03, 2011 | Briggs & Stratton Prosumer 2800 PSI (Gas -...
Oil quanity
Should be 4 1/2 quarts. If you are changing it yourself add 4 quarts then after a minute or two check it. If it's between the quart low and full line. start the car, then let it sit a few minutes and check it again. If your changing the oil filter the oil will fill up the filter when you start it therefore the level will go down.
Thank you and good luck,
Lee
Oct 12, 2010 | 1998 Ford Escort
There are no markings on the dipstick to know where the acceptable level for the oil is on the 1996 Millinea. How do I know if I have enough oil?
Drain the crankcase oil into a clean container in which you are able to measure the amount. Replenish this amount up to the quantity stated in your hand book. Remove dipstick and fill the crancase with just this oil. Dip the oil level and using a scriber or a file, mark the dipstick at the level of the oil.
Notes:
1. The quanity of oil is the engine capaity less the oil filter.
2. You may wish to use clean new oil and fit a new filter. If so, use the fill capacity including the oil filter, or add about another pint.
Apr 13, 2010 | 1996 Mazda 626
What oil, how much oil, and how change oil on pump of ry80030a
The RY80030 Pressure washer has a Faip pump on it. There is no drain plug and you do not change the oil in it. The pump only holds 4.5 ounces of oil and the pump only has a life expectancy of between 30 and 50 hours. If for some reason The oil gets drained, remove the pump from the motor and set it on a bench standing up on end. Remove the allen bolts holding the water and oil sides of the pump together.Be carful as the piston springs are under load. fill the pump 3/4 of the way full and replace the head. there is a smoke stack on the pump but it is simply a breather not an oil fill.
If this helps please rate this post. Bill the Tech
Dec 17, 2009 | Karcher 2500 PSI Pressure Washer
Does the Freerider kensington have oil in the drive motor? if so how do I check it and what type and quanity does is it use? Also does anyone have a workshop manual for this
No Oil but you do have a grease nibble located on top of the gearbox, get hold of a grease gun and give it three squits of grease.
Regards
GeWiz.
Mar 15, 2009 | Health & Beauty
FAIP 2100psi 2gpm Faip Power Pressure Washer Pump Only Logo
637 people viewed this question
Top FAIP Garden Experts
andy just round the...
Level 1 Expert
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Mister Danger
Are you a FAIP Garden Expert? Answer questions, earn points and help others
