Question about GE Profile JTP56 Electric Double Oven
My oven says F7 with a constant beeping sound every minute on the minute. How do I get it to stop and what does it mean?
  • 2,382 Answers
The code can be caused by a faulty keypad or a Stuck keypad which may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel. :
furtrhermore
Posted on Oct 14, 2010
  • NeilC Denver Jan 15, 2011
    We tried both 2) shutting off all electricity from the circuit breaker for 10 minutes and 2) disconnecting the ribbon cable from the control for 10 minutes as well. Nothing worked. At this point, the tactile front panel works, but once either oven is on for a half hour or so, the F
The General Electric under the counter oven is beeping and only stops when I push the Clear/Off button. Then it resumes beeping 1-2 minutes later. Also "F7" appears to the left of the time...
The F7 error code means that a key on the touchpad has shorted and the touchpad needs to be replaced... sometimes it's a electronic anaomily, since you have pushed Clear/off and the F7 returns it surly means that touchpad is bad.
GENE
Sep 09, 2011 | General Electric Ovens
I'm getting a constant beeping sound and a F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Aug 10, 2011 | Magic Chef 9112 Gas Double Oven
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
Oven beeps and shows F7.
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
thanks.
Sep 29, 2010 | GE JGRP17 Gas Single Oven
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Aug 19, 2008 | GE JKP15 Electric Single Oven
Oven error code
See my solution to OVENMAN/April 12, 2007. I have supplied my fix to over 650 individuals and have had a high reported success rate.
Mar 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile JTP56 Electric Double Oven Logo
559 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
