Question about Mitsubishi WD-57733 57" HDTV
I had this TV WD 57733 for the past 5 yrs, and since last year it has started to switch off after a cold start in less than 3min of turn on, the amber light stays on and the green light blinks for 30sec. After that I can turn on and the amber light will go off after picture & sound comes on. Now this has become more frequent.! Any ideas? I have been keeping the back clean every month near the lamp..THx
  • troosh364 Oct 14, 2010
    Ok, I will try replacing the ballast and the lamp and let you know. Thank you very much for all your help.
    Sergeant:
  • 171 Answers
Have you replced the lamp in not you need to replace it
if you have then you have a ballast issue
you still need to repalce the ballast anyway
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Posted on Oct 14, 2010
    Thank you very much for getting back so soon. Do you think its the bulb as when the TV is on after the switch off, there is no shut off/low brightness or any of that sort of issues. It runs fine. But every time it is turned on after a cool down (more than 2hrs) it will do that! I just want to be sure that it is the bulb/ballast.
    THX!
  • BONES420 Oct 14, 2010
    well this lamps are rated for 6000-8000 life hours witch equal to 2-4 years of average use
    so if you still have the original lamp I would say you need one anyway but you have a ballast issue for sure the lamp does not have the capacity to turn on or off but the ballast does
    I found the lamp you need just in case
    http://www.discount-merchant.com/SearchR... 57733
My WD 57733 will attempt to power up (almost like a whistling sound as it attempt to power up) then will power back down.
When was the last time you replaced the lamp? That sort of sounds like the ballast is unhappy with a bad lamp. The 57733 is a good TV. The other possibility is a stuck/dirty color wheel.
Check the lamp and see if it looks worn out(dark or grey in the tube down the center). Also make sure its either a Philips brand or Osram brand.
Let me know and Ill see what I can recommend next
Sep 12, 2016 | Mitsubishi WD-57733 57" HDTV
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
How to remove and install tv lamp for model wd 57733
See page 62 of this manual. Read the section titled "Lamp cartridge replacement". It has detailed info with pictures.
http://www.retrevo.com/support/Mitsubishi-WD-57733-TVs-manual/id/3124bh436/t/2/
Feb 06, 2011 | Mitsubishi WD-57733 57" HDTV
My tv model wd-57733 has hundreds of black and white spots on screen.what is the cause and how do i fix it?
I developed white spots on the screen of my Mitsubishi WD-57734 in increasing numbers over days and weeks. I called a repair service who quoted me $1500 to replace the light engine. He suggested I call Mitsubishi Customer relations at 800-332-2119 option 5 which i did. To make a long story short after several conversations with them they agreed to replace the part for free if I picked up the labor (Would have been less conversations if I had the original purchase receipt). Instead of $1500 I paid $250. The tv was only 3.5 years old. Perseverance paid off.
Dec 28, 2010 | Televison & Video
TV TRIES TO POWER ON GREEN LIGHT COMES ON THEN TURNS BACK OFF AND DOESNT END UP TURNING TV ON?
If you get audio and it does that, it's a bad lamp. Had that happen to mine last month. Check your lamp.
Nov 22, 2010 | Mitsubishi WD-57733 57" HDTV
WD 57733 picture color problem
Good Day;
Try resetting both devices TV & BOX, unplugg power for 2 to 5 minutes then plug back in.
good Luck, big IRISH.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Starting system cold, no sound for 2-3 minutes
Its not worth having it looked at. $100.00 for a new 400.00 unit? My unit is doing the same thing. Turn it on and 2 to 5 minutes later it may come on. Change to video 3 4 5 etc it stop again. Only works with a cold start. Something in the unit has failed and is heat related. My original Kenwood 20/20 recevier still works. Must be 40 years old. New products just last 5 to ten years max if your lucky.
Dec 17, 2006 | Kenwood VR-6070 Receiver
Mitsubishi WD-57733 57" HDTV Logo
250 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
