Question about Garden
My mother-in-law said her lawnboy just quit running, so I brought it to my house to check it out. It appears to me it isn't getting gas. I took air cleaner off and sprayed some carb cleaner in and it ran as long as I kept spraying. I assume it is a carb problem. Any suggestions? The model # is 10330
  • damko08 Oct 14, 2010
    I assumed that it was the carb, but thought it could be something else. Thanks
You will need to disassemble, clean, and then reassemble the carburetor. This should get it back running again but since you will have to take it off you might as well rebuild the carb using new gaskets and seals (if you plan on keeping it around for five more years) You are looking at a dirty carb or a carb that will need rebuilding.
http://forums2.gardenweb.com/forums/load/lmower/msg0620215517102.html
Posted on Oct 14, 2010
Why did my lawnboy lawn mower quit while it was running?
If your not out of gas then loosen the fuel cap a bit and start your engine. if the unit keeps running then replace your fuel cap because it's not venting which builds up pressure in the tank and stops fuel flow. Another possibility is that you got dirt in your carb and it's blocking a passage. In this case clean your carb
Jul 16, 2014 | Garden
My honda CH-50 metropolitan scooter isn't getting gas from the tank, our friend drove it all around florida and then brought it up to us, we think he flipped a fuel cutt of switch when he shipped
The problem is most likely a blockage in the carb, or air filter. check the air filter and then clean the carb. You may just need to run some fuel system cleaner through the engine, you can do this at idle.
Jun 15, 2012 | Honda Motorcycles
Just recently my grandmother die, she left some of the properties without last will and testament, she has three children two of which has died over 20 years ago now my mother is the only living.. my...
*********** has every right to claim for the mothers property and every evidence will be needed to prove that she was close to her and took care of her mother.
It is best that you must seek LEGAL OPINION FROM A CIVIL LAWYER- know to you- who can advice and be loyal to you - based on the law of your land.
Also try and get a consensus and settle amicably if by compromise than to drag the matter to court-- as humans we can communicate and negotiate to solve.
Good luck.
Sep 12, 2011 | Health & Beauty
Lawnboy model 10795 is not getting gas to cylinder. I choked and pulled and took the plug out and it is dry.?
is gas getting to the carb, if so check the flote boul to see if its being let in
I would also spray some fuel throw the carb ans start it up ,it sould run for a few seconds and may just free up what every you have going on, maybe just keep lightly spraying some in through the carb to run it for a short time
Be Carefull Doing This, Loose Gas and Exsust Do Not Mix
Aug 01, 2011 | Garden
I took my father in law's Remington 1.25hp
PRAY! NEVER BORROW a father in laws equipment!!!! Let it sit for a short time and cool down and then see if it will start. I would also check the air filter and make sure that it isn't plugged!
Jun 24, 2011 | Remington Garden
I am trying to fix my mother-in-laws Magic Chef cook top (Model # 8241 RB). It is a gas model. It appears the all four of igniters are not working. My mother-in-law said they stopped working one at a...
Suggest that the new igniter is defective.
The bath tub concept of early failures is the most likely explanation this recurring failure,
The prior failures relate to the late in component life the far end of the bath tub curve.
Hope this helps?
The Bathtub Curve and Product Failure BehaviorPart One The Bathtub Curve...
Jun 29, 2017 | Magic Chef CGC2430 Gas Cooktop
I have a 1987 commercial lawnboy walk behind mower that has stopped running. I gradually lost power over the summer and now it will not start. I have installed a new plug and filter earlier in the spring....
I would try and remove carb and clean it thuroughly. You can soak the parts in solvent or equivelant. The carb would be right after the air filter tube to the intake of engine.
Aug 25, 2009 | Garden
Lawnboy 10685 mower surging problems
I hope that the shop didn't rebuild the whole mower engine for you if you took it in for a surge. If you mean they rebuilt the carburetor, that's what it needed. I'd call them, tell them it's doing the same thing as it was before (starving for gas, causing the governor to "hunt"). The carburetor is dirty inside. You have a blocked/partially blocked jet. You can either take the carb off yourself and try to clean it, or take it back to them and let them try again.
Here is a thought. First, before you take it back to the shop, take the small bolt on the bottom of the carb. This holds on the bowl. You do not want to take this off if the machine is full of gas, cause it will leak all over your mower/floor. Tilt the mower backwards or try to drain the gas out. When you get this little brass bolt/nut out, and get the gas cleaned up that leaked out, if you look real hard you will see a very tiny little hole in the shaft of this little bolt. Some even had 3 of them. It may appear to be just a blemish in the finish, but it has to be clean to allow proper operation. Spray with carb cleaner, and take a small wire, such as a single strand of a speaker wire or something similar. Clean that hole/holes out. Clean out the inside of the bolt shaft as well, as debris will settle in there. Put the bolt back in and tighten the bowl up. Make sure the bowl is straight and the gasket is back on the little brass bolt. Tighten snuggly, but not forced.
Try that. If it works, and the mower runs better, put some carb cleaner in the gas and run a bit.
May 17, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
201 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
