Question about Coby DVD-224 DVD Player
My DVD player was working both with Remote and the buttons. now, the DVD player is not responding to Remote. The Remote isFine (tested). TRUMAX company set, ONE IC, model 6283 MMC (Delhi assembled). Purchased on October-2009. Please any one help me? (91-9247200775)
3 Suggested Answers
SOURCE: Coby 626 DVD Player Remote Not Working
I have a COBY DVD player TF-DVD7005 that hadn't been used in a while. When I charged the battery and the light went from red to green, nothing happens when I push play and the DVD doesn't spin. Could the battery be dead despite the green light and where would I get a new one?
Posted on Jun 05, 2008
stonephoenix
  • 563 Answers
SOURCE: philips universal remote not working for my coby dvd 224
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Posted on Apr 17, 2009
The buttons on my DVD vcr don't respond
get a remote,it will be cheaper,I had the same vcr,it did the same thing,a circuit board burned up. Samsung 00008A DVD Remote Control for DVDV3650 DVDV3500 DVDV8080 Tested...
May 12, 2017 | Samsung Televison & Video
Problems ah59-02303a not working
The remote can be tested--shops use a card which when remote is pointed at and buttons pressed--a strip on the card lights up.
Many digital cameras in a dark or very dim room will react on the display screen in the same way--faint flash will be seen if remote is working.
If remote is tested and found to be good---try it very close to unit--you if no response at all and remote is good have a bad remote receiver in the unit(make sure the receiver lens is not blocked or dirty).
Apr 24, 2012 | Samsung BD-C5900 Blu-ray 3D Player
I have a JWIN VD519 DVD player that has worked fine till this evening. The remote suddenly stopped responding even after changing for new AAA duracell batteries. Nothing has been spilt on the remote...
Hello
you can test your remote with a mobilephone camera like this:
open camera on the phone an hold the remote front against the camera
(approx 10cm from it) press a button and look in the display on the phone.
if the controller works you should se a blue light in the display coming from the remote front.
if no light: try other batteries again note the battery polarity. no light= controller broken.
if there is light= the remote is working. try to disconnect power from the DVD for a few minutes,
and try again. if it still not works the player is propably broken.
Good Luck
Sep 05, 2011 | Jwin JD-VD149 DVD Player
Hi, My Samsung DVD player remote would not respond when power button pushed on. When DVD power turned on Manually and DVD loaded the remote would not respond to the play, arrow buttons eirther?? My LG...
If the buttons on the case are working but the buttons on the remote don't then it's clearly a fault with the remote.
Each button in the remote is made out of 2 wires on the electronics board that are joined by a small patch of conductive paint situated on the rear of the rubber button. If something gets in there, like water or dirt or the patch flakes out, the contact is no longer made and the button no longer works. The remote will have to be dismantled by popping the clips on the periphery with a sharp tool, the rubber strip holding the buttons will have to be washed and the board wiped clean. If the buttons still don't work after that then the remote is dead, you will have to get another one.
Jul 24, 2011 | Televison & Video
The remote to my RCA DVD Player, Model DRC220N, has stopped working. I've tried new batteries, hitting the DVD button 1st, etc. Nothing works. The player itself still seems to work as the buttons...
You could try a universal remote (if one is available which will provide most functions to your player, such as STOP/PLAY etc.).
You can try a simple test on your existing RCA remote to see if it provides a 'frequency pulse'. Turn a radio on, select a black section of the AM band (not FM) turn volume up halfway, place remote near it, listen for pips and noises from the speaker(s) - if this occurs, the remote itself is OK. This is the cheapest idea to try first before going out and buying a new remote.
* If the unit does not respond to the universal (regardless of whether a remote code is required or not) then the IRD within the unit itself and its associated controller circuit may have failed (hence why the remote does not work). Repair of this requires a qualified workshop technician (because of the many surface-mounted components in the IRD controller circuit). *
But try the original remote-to-AM-radio test and/or purchase a universal remote or similar if necessary.
May 12, 2011 | RCA DRC220N DVD Player
Player is quite old but used very little. Will not respond to remote. Do you think it is worth having it repaired. If so can you; refer me to an authorized facility in central Maine.
Test the manual buttons on the DVD player itself,see if it work,like play a DVD disc?The remote is the only thing is having the problems?Yes,try website like Remotes.com to buy an new original remote.If the DVD player itself is have a problems,not worth fixing,because DVD player devices are very cheap these day.U could buy a whole new one like 40-45 dollars.
Mar 16, 2011 | Cyberhome CH-DVD 300 DVD Player
I have the Sony dvd changer that holds 400 dvd's and the remote was working fine one day then just stopped the next. I've changed the batteries and the light turns on but the player just doesn't respond
to test remote shine it into camera ( turn on camera ) press button you should see light flashing if not open remote and clean circuit board and battery contacts
Dec 04, 2009 | Sony Televison & Video
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Remote control "enter" will not respond in DVD mode
I had the same problem. Powering down and rebooting (unplugging) the recorder fixed the problem.
Mar 12, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Coby DVD-224 DVD Player Logo
27 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
