Question about SanDisk Sansa e250 MP3 Player
Refresh database hello hope u can help me.. the refresh database screen pops up and then it automatically shut off. how can i rectify this.. need your help the soonest. thanks, allie
  • 8,596 Answers
Firmware upgrade needed:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 11, 2008
Office Access 2007 Advice
Me.Refresh
or
Forms!'NomFormulaire'.Refresh
i can help but more info is needed
May 23, 2017 | Microsoft Access 2007 Full Version for PC...
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Hello
hold the off switch until it shuts off. than put it back into the computer and eject it. it should refresh normally and quickly
Feb 28, 2008 | SanDisk Sansa Clip MP3 Player
Refresh database
I had the "Refresh Database" problem with my C250, it just sat there after turning it on! However, the GOOD NEWS is, I corrected it! First I connected it to my PC, then FORMATTED the unit. This gave me an empty player that at least would turn on. Then I downloaded the Sansa "Updater" from the SanDisk website. After setting up the updater software, I connected the C250. It automatically checked for any new firmware, and loaded it into the player. After that I restarted the C250 and it again came up OK without any music loaded. The last thing I did was to load only 1.8 GB worth of music files. My take on the problem is that if you overload the memory, or interupt a file while loading, then the "datbase" function never gets done. I've had mine running for about a week now without problems! Hope it works for you too! <Good Luck> David
Jan 19, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa
Dec 25, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Refresh Database
I have the same problem and can not figure it out!!! how do I refresh database??!!!grrrrrr
Need help as well.
Thanks
Dec 12, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
My e200 mp3 sansa player can get refresh database
Hey Do the recovery Turn ur mp3 off lock it and hold rec and on it wiil have u plug in the usb cord and leave it there for 5 min And unlock then it will turn back on its self
Aug 19, 2007 | SanDisk Sansa e200 MP3 Player
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
19 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
