Question about Panasonic AG-DV1000 Mini DV VCR
AG-DV1000 Mini DV... ERROR F09
WHEN I TURN IT ON GIVES THE FOLLOWING MESSAGE....
FO9
  • 4,234 Answers
I believe that this error message indicates that the heads are not spinning. The tape should be ejected. This unit requires a servicer. There are a number of reasons for the heads not spinning. Finding out the cause in your specific unit will require testing and measurements with test gear. There are no user serviceable parts inside these units. Please see an authorized Panasonic service center.
Dan
Posted on Jun 03, 2008
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Feb 25, 2014 | Panasonic AG-DV1000 Mini DV VCR
I have a AG DV1000 mini DV deck I can't turn it on no powerat all, how can ai fix it , where have to send it?
Hello, thanks for using Fixya.com
I would check another power source, if it still does not turn on you might have a bad fuse inside the unit witch would need to be replaced and inspected for cause of blow out.
Panasonic would take it under out of warranty bases you might want to give them a call and ask about a local factory repair shop. Most VCR and TV repairmen in your local area if you cannot find a factory service center would be your best bet.
I would not open the unit unless your knowledge fits your budget because of hazards and other occurrences can occur.
Give this website a shot for parts and service locations
Please let us know if you have any further questions,
Best regards,
Rulds2008
Jun 14, 2011 | Panasonic AG-DV1000 Mini DV VCR
Panasonic deck ag dv2000 gives error code f09
Your vcr seems to use the K Mech. F04 Means that the mechanism locks unloading.
The cause of which might be the loading motor timing.
F09 means No serial clock linking IC2004, IC7005 and IC7701.
Apr 29, 2009 | Panasonic AG-DV2000 Mini DV VCR
Will not seat DV
most likely problem is a defective cassette housing.
Jan 11, 2009 | Panasonic AG-DV1000 Mini DV VCR
Will not power up at all!
check the main board for bad solder connections near the power connection.
Oct 28, 2008 | Panasonic AG-DV1000 Mini DV VCR
Unfortunately, all I know about Muncie is that I have relatives there. I'd go to the Panasonic website and use your zip code to locate a local authorized service center. Follow the link below and click on the "find a servicer" button in the upper right corner.
Dan
http://www.panasonic.com/support/?cm_re=1-_-Top%20Mast-_-Support
Aug 20, 2008 | Panasonic AG-DV1000 Mini DV VCR
AG-DV1000 Mini DV
The message indicates that an internal problem was detected and that the unit has shut down to prevent damage to the tape. The tape will need to be removed by hand. I can not receommend a repair location without knowing where you are.
Can you post an update with your location?
Thanks,
Dan
Aug 19, 2008 | Panasonic AG-DV1000 Mini DV VCR
Cant record in Panasonic AG-DV1000 using firewire
clean the heads; often, heads that will play back a pre-recorded tape may not record because of dirt.
Feb 21, 2008 | Panasonic AG-DV1000 Mini DV VCR
Error H U 11
U11 is a "dirty video heads" message. Either use a cleaning tape or have the unit professionally cleaned.
Feb 17, 2008 | Panasonic AG-DV1000 Mini DV VCR
Panasonic AG-DV1000 Mini DV VCR Logo
200 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
