Question about Staples SPLXC200D Shredder
Where do I get replacement parts for my Staples SPL-XC200D paper shredder?
SOURCE: Mr.
I found a way to do a fix that should last for awhile. Put the large gear in a vise leaving room to partially knock the small broken gear through. I used a bolt the same size as the hole in the plastic, and tapped it in about 1/4 inch. This pushes some of the small gear through, exposing more of the usable part of it. I then cut (hacksawed) off about 3/8 inch of the broken part, put it back together and it works!..................Good luck, Sparky
Posted on Dec 15, 2008
  • 7 Answers
SOURCE: Have a Staples shredder SPL 1506X and need to find
no there is not
Posted on Jun 11, 2009
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
SOURCE: staples SPL-770M shredder with overheat light even when cool
Just a FYI: I had the same problem. Nothing appeared jammed. But I took the housing cover off and low and behold the rubber roller that turns the shredders had MELTED to the inside. That's why it wouldn't work. This happened while shredding a single DVD - something I had done effortlessly on numerous occasions. You may want to check to see if the roller melted or if some debris has jammed up inside the unit, like mine did often.
Posted on Jan 08, 2010
SOURCE: Drive gear for staples shredder Model# SPL-770M is worn
is it the drive gear or is it that the shreader is dull that makes the shreader sluggish?
Posted on Jun 23, 2010
I have a staples spl-xc200d paper shredder. It runs on auto is that normal
If I understand the question then yes it should run on auto when the paper is inserted to be shredded. I have this shredder as well and mine is always set to auto.
Apr 19, 2017 | Staples Office Equipment & Supplies
Staples shredder parts
You can try cleaning it and maybe limiting shredding to one sheet at a time.
Jan 14, 2014 | Office Equipment & Supplies
Staples spl-xc200d shredder will not power up
Check the breaker, otherwise it may be a faulty unit. Contact Staples for more details.
Oct 14, 2013 | Staples Office Equipment & Supplies
Parts manual for SPL-TXC122A
I need a plastic gear for the Staples SPL-TXC122A Does anyone have one?
Apr 06, 2013 | Staples TXC122ACC Cross-Cut Shredder; 12...
Staple Model SPL-XC200D Paper Shredder, During the
Fixya does not sell parts and cannot identify sources.
Jul 18, 2017 | Staples SPLXC200D Shredder
I need to replace the plastic guides in a Staples
did you ever figure out where to get these guides? i need them too. jeff
Jul 22, 2010 | Staples SPL616X Cross-Cut Shredder
Paper shredder spl-xc200d
We are having the SAME problem...what ended up being the problem??
Sep 08, 2009 | Office Equipment & Supplies
Staples SPLXC200D Shredder Logo
326 people viewed this question
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
