Question about LG Electronic Window Air Conditioner
There is power to my LG lwd1800hy air conditioner and I have tried the reset , but unit does not run? Help!!
Turn off the power from the circuit breaker and wait three minutes before powering up. This should reset the system. If it still does not run then you will need to replace the compressor motor
Posted on Oct 14, 2010
Lg intello air ac led blinking many times but compressor and indoor unit are running
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset West Palm Beach Air Conditioning
Jun 01, 2016 | LG Heating & Cooling
Lg air conditioner t-stat temp sensing bulb
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset.Air Conditioning Coral Springs
May 25, 2014 | LG LWHD1800R Wall/Window Air Conditioner
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
My lg lwhd7000hr air conditioner won't turn on there is power to the cord and the reset button stays on.
Does it have a position for fan only? If it does try that and see if the fan will run. If it doesn't something is keeping power from getting to the fan and compressor. Try looking inside for a fuse or possibly a capacitor. There may be a small transformer inside the unit. Check it for 24vac. If the fan runs then the transformer should be ok.
May 01, 2010 | LG LW7000R Air Conditioner
Indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Apr 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
LG 250 Volt, 18000 btu window air conditioner. Tested power on the outlet, and that is fine...but will not power up the unit. Have already tried the reset and test buttons, still nothing. Any help would be...
Take cover off of electrical compartment, locate power on off switch, see if you have proper voltage before and after switch, if power is present locate thermostat, check the same way, also look for burnt wiring, Good luck.
Mar 04, 2010 | LG Heating & Cooling
LG M8003L Air Conditioner does not power on
i think there may be damage to a small electrical component in the circuit board which probably fried just before breaker popped open
Aug 12, 2009 | LG M8003L Air Conditioner
I have a LG window AC Model LWHD8008R. Won't power up?
Replace reset switch or bypass it to make sure it is the problem. Check for low voltage while the unit is on. Shoud stay above 105 vac
Jun 28, 2009 | LG Heat cool Window Air Conditioner
LG LS-Q09BUL INVERTER AIR CONDITIONER
This is possibly either a complete outdoor pc board error or an E-Prom error on the indoor pc board. You can try shutting down supply power completely for a minute and then switch on. These units also have a delay timer system which does not like to be switched on, off repeatedly in a short period. Please also check for reset button on the outdoor pc board. Hope this helps.
May 12, 2009 | LG Heating & Cooling
Lg split system air conditioner
Try sutting off the power to both units. This may reset the unit. Check out the service manual at LG website www.lgusa.com. Go to their support page and put the model number in. Remove and replace the batteries in the remote. If there is a communication error, the inside unit will display 3 flashes. If all else fails, call LG at 1-800-243-0000. Good Luck!
Jun 13, 2007 | LG LS240CE Split System Air Conditioner
LG Electronic Window Air Conditioner Logo
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
