Question about HP Photosmart C6180 All-In-One InkJet Printer
0xc18a001 - HP Photosmart C6180 All-In-One InkJet Printer
  • 570 Answers
First unplug the printer, remove the ink cartridges, then re-install the new printer cartridge
If this did not work then follow the alternate steps and fix it .
Resetting HP Photo smart C6180
1 . Press * and # at the same time
2 . Press 1, 2, 3 and "support R0632M" should display
3 . Press > and "information menu" should display
4 . Press > and "configuration menu" should display
5 . Press OK and "hardware failure status" should display
6 . Press OK "failure status: clear". Press OK to clear
7 . Press CANCEL
8 . Turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
Now you are done.
Thanks.
Posted on Oct 14, 2010
.photosmart c6180 ink system has failed unable to copy recieve fax or printerror 0xc18a001
As always I start with the dreaded question. Did you use a refilled cartridge in your printer? If so, remove it and install a new HP cartridge. Recycled cartridges are famous for this type of failure. By the way the error code is a Windows error code. If you haven't found a solution to the " ink system failure " yet, it is quite easy to reset (using the buttons) on HP C7180. You can find the reset instructions on my website: http://www.inkbank.com.au/webcontent21.htm
Try this:
May 04, 2015 | HP Photosmart C6180 All-In-One InkJet...
Hp error message 0xc18a001
Here is a fix I found on the internet, can't specify as to it's reliability, cause I don't have one of those printers.
Gently remove the side cover of the printer. Start by opening the top cover and inserting a small screwdriver in the small tab slots. Going around the edge of the side cover, gently pry it off, being careful not to break any of the plastic snap tabs. You'll have to pry the front piece under the nameplate, also. Once off, gently remove the two white ribbon connectors just below the top cover. Turn the unit back on. You will get an ink carriage jammed message. Turn the power off and reattach the two ribbon connectors. Turn the power back on and the ink system failure message should not reappear and the printer will go through its set up program and be functional again.
Dec 26, 2011 | HP Photosmart 3310 All-In-One InkJet...
Error0xc18a001 i cant print because of this message what do i need to do ? please help
ello thanks for using Fixya
To solve the error code
0xc18a001. There is following solution.
Follow it step by step
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
By this error will automatically remove. But if u face still this error then printer service required
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 14, 2011 | HP Photosmart C5180 All-In-One InkJet...
I hav installaed new cartridges but the is offline and i cant
I have a Printer problem - "Ink System Failure" - Ink System has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: 0xc18a001". This is what the glass on the left side says. I don't use faxes, so don't care of that. My Son installed an ink system, which of course is a lot cheaper to use, quite some time ago which has been working super. Yesterday the "Ink System Failure" sign came on and my Son was here this morning, but couldn't figure out what is wrong with the printer. I am in Heidelberg, Germany and buy my equipment in the AAFES PX. There is no HP technical service available to us Military people. The Germans won't work on American goods. Is there any hope for me? Thank you.
Phil Gatchell
P.S. I am the Adjutant/Finance Officer of an American Legion Post in Heidelberg and use my color printer extensively. So I am in a bind.
Jul 17, 2009 | HP DeskJet F4280 All In One Printer InkJet
Ink system has fail. unable to copy receive faxes, or print. Refer to printer documentation. Error: 0xc18a001
i can not feed paper at all or copy to paper but i can scan files to my computer how can i fix this
Mar 01, 2009 | HP Photosmart 3210 Printer
Error oxc18a0001 on screen, can't print?
1215 hp photosmart printer won't print in color. put in new cartridge and uninstalled it, didn't help
Sep 21, 2008 | HP PhotoSmart 1215 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
503 people viewed this question
Seeker5211
Seeker5211
