Question about RCA D52W19 52" Rear Projection Television
3d image/sinking effect
We were watching t.v. and picture had a 3d like effect but started sinking into middle,almost like bowtie shape...top and bottom cut off... can i fix myself? ,if so whats the prob? how much would a repair man charge?
  • 4,234 Answers
This is a convergence problem. Ther are either bad connections at the convergence ICs or the ICs are defective. If you can solder, you can repair this yourself. Try resoldering the pins on the ICs first. If that fails to resolve the problem, replace the ICs. These ICs are large, black and attached to a heat sink. They should be marked STKxxx. Figure on $20 for each one. There will be 2 of them.
Keep us posted.
Dan
Posted on Jun 02, 2008
Can i get a customized sink mat?
If by customized you mean size-wise, most plastic and vinyl sink mats allow you to cut them both on the outside and inside, to adjust them to your sink. You can make them smaller, cut a hole in the middle to open the drain, and cut any shape you like.
This mat for example, shaped as a cluster of pebbles, can be cut with regular scissors to remove unwanted "pebbles" and adjust the size of its drain-hole:
http://www.containerstore.com/shop/kitchen/sinkArea/sinkOrganizers?productId=10028622
Same thing for this flower mat:
http://www.organizeit.com/blumz-flower-sink-mat-clear.asp
If, instead, you would like to create your own mat, customized in color, shape and style, you can contact a 3D print service and ask them to print your special mat, or to design and print one for you.
Here is an example of a 3D print service website:
http://www.shapeways.com/
Nov 14, 2013 | Home
55lw5600 3d not working correctly. Put the tv in 3d mode and the pictures do not line up correctly.
Try to wear the eyeglass for 3D and, that is the effect of 3D mode. good day sir
Aug 21, 2011 | LG 55 55LW5600 3D LCD TV
Not sure if its a picture tube problem or convergence problem. TV was working fine, put a DVD on pause, came back 10 minutes later and poof! Distorded picture almost 3D like. Shut it off and when it came...
Check the micro fuses that power the convergence board, one or two maybe open, While doing this also resolder the flyback transfomer and area around it. Check for cold solder joints in this area as well.
Replace any open fuse with 5amp same type. If fuse are good then convergence power board is faulty and needs serviceing or replaced.
Dec 21, 2009 | RCA HD52W58 52" TV
Poss. convergence problem with Hitachi 53UDX10B Ultravision
You have convergence problem. Either bad connections on ics, ics are bad or voltages to convergence circuit are missing. There are no bulbs in this set. 3 picture tubes,red,green and blue produce a picture than when alighned(converged) correctly on top of each other gives you a color picture.When not you get the effect you are describing. Frst you can try the magic focus in the menu.
Apr 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Picture problem with rca 52 inch hdtv colors split not in focus
Hello, If your picture looks like a "3D image" you need convergence IC's . Red and or blue picture is not converging on top of the green picture. They are mounted on large, finned heat sinks. The # on the IC's starts with "STK-" followed by numbers.They are available through tritronicsinc.com for $15 to $35 each. Good luck.
barneyluc
Oct 10, 2008 | Televison & Video
3D image
you have to replace all 3 ic's and 2 are stk 392-110 and the 3rd one is stk 392-150 they are located on the extreme right of your tv on a long heat sink all 3 are located there.You can get replacements as well as free tech online support at
http://servicemanuals.vstore.ca/
Apr 10, 2008 | Hitachi 51UWX20B 51" Rear Projection...
Bow like image
You likely have bad convergence output ic's type #STK392-570.  These can be purchased at UED 800-648-6657.  You will need to remove the board they are mounted on to be able to usolder the old ones and resolder the new ones.  These will be mounted on heat sinks.
Sep 08, 2007 | Mitsubishi WS-65819 TV
Apex gb4308 multi colored horizontal bow in middle or screen.
This is not an "STK" problem. Your problem is VERTICAL. You need to check your vertical chip for damage CN301 and check around it for any bad parts or loose connections. I've seen loose connections on the chip itself cause it to self-destruct.
Apr 11, 2007 | Apex Digital GB4308 43" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
62 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
