Question about Sharp AL-1641CS Laser Digital Copier
When, I turn on my printer, I recieve a blinking H and 4 as an error message. What does this mean?
  • 46 Answers
H4 error is heat roller low temperature, try pressing # * c * to get into simulation mode and enter 14 and press start the follow instructions on screen (should be press ok). This will reset the code and restart the machine. When the machine restarts if the error was a not mechanical the machine should go. If not you have one of two most likely problems; you need to reset the thermal cut-out on top of the fuser unit or the fuser lamp is blown.
Posted on Oct 14, 2010
Tip
Canon Service Error 5202
Service Error 5202 solution for ip1800 / ip1900<br /> <br /> Steps: <br /> 1. turn-on printer, still blinking and a error message on screen, open cover. <br /> 2. While printer cover is open, unplug the power cord at the back. Of course it <br /> turns off. <br /> 3. Remove all cartridges, clean the contact points and then insert them back <br /> properly. Move the entire cartridge to its parking area. <br /> 4. Close the printer's cover, plug the power source, turn the printer on. <br /> <br /> 5. It should be working fine now. Mabuhay!!!
on Mar 24, 2011 | Office Equipment & Supplies
The yellow and green light flashes and printer error 5200 message displays
Error NO. 5200 is caused by ink absorber almost full so you need to reset your printer.. To solve the problem follow the instruction step by step ;
1. Turn off the printer without pulling the power cords.
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Then Press Resume button 5 times then let BOTH buttons go.
5. You will notice that the Alternate Blinking error is gone, this means that the printer is in Service Mode state. thanks
Aug 28, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My Kodak Esp 5 want scan and I received a error message after trying to scan
is this the error message you recieved 1-2000 or tricode code for example 235x892. please verify what error message you recieved. Now if your recieved an erro mesage numbers you may need to reinstall the software of your printer. please download the latest software and drivers of your printer at kodak.com/go/downloads
Nov 21, 2009 | Kodak ESP 5 Printer
Error 50c, recieving this error when trying to print or make a copy
Hi there Error 50c
It works for the 940 it may work for the 960 too.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Oct 07, 2009 | Dell A960 All-In-One InkJet Printer
I have a ML-2510, I turned it on and both the red light and green light flash constantly. Will not feed or print.
The green light blinking means that it is accepting or printing data.
But, the red light is for the error messages. This blinking means there is a toner problem. 1. remove toner cartridge from printer and gently shake to redistribute any that is left, or
2. You simply have to replace the toner cartridge with a new one - this one has been exhausted.
Jul 09, 2009 | Samsung ML-2510 Laser Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Printer error e27
This error means waste ink counter is full.
Solution:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Press resume
Aug 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error message on startup
The fuser unit could be the causes. But you can try this, power off the printer & unplug the power cord for 15 to 20 minutes. Power on after 20 minutes and se whether the problem resolves, if it ok, monitor it for a while just to make sure the problem resolves
Nov 20, 2006 | HP LaserJet 4 plus Printer
Sharp AL-1641CS Laser Digital Copier Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
