Question about Stanley FactoryReconditioned Bostitch UCAP2060P 105 Amp 2 Horsepower 6 Gallon OilFree Pancake Compressor
I have a Stanley/Bostitch CAP60P-OF -- Oil less. Runs, but does not deliver much or very little pressure. Could I get a manual to help solve this problem?
  • 236 Answers
SOURCE: On a Bostitch CAP60P-OF air compressor I can get
i also own a bostitch and it works great, the pressure regulator knob on mine is red not sure if yours is the same color but just turn this knob until you get the nail depth that you need , it should be near the pressure gauge, a quarter turn of this knob at a time is recommended until you get the pressure you need, i think you turn it in the loosen direction to get more pressure
Posted on Jan 23, 2011
Testimonial: "I think you solved it. The threads are stripped that the red knob screws into. Thanks."
  • 3 Answers
SOURCE: Stanley bostitch coil nailer gun
check the safty shaft and see if something could be under trigger safty causeing it to fire.
Posted on Feb 20, 2009
smjdragonfly
  • 79 Answers
SOURCE: air coming out the trigger of a stanley air gun
Go to the Stanley Bostitch website. Click on schematics & parts. Find your model number in the drop down list. There is a list of parts and pricing. Just above the parts is a link for the schematic. Honestly, I worked on these things for years. It is best to replace the entire trigger valve. It comes as a kit with instructions grease, and a little tool to hammer your pins out. Lemme know if this helps. Please rate me
Posted on Jun 18, 2009
ollie reece
  • 1167 Answers
SOURCE: Bostitch Air Compressor cap60p-of will not shut off
hi mate you can try and adjust it but if this problem has just started then you need a pressure switch replacement
Posted on Aug 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: I purchased a Stanley Bostitch N80 framing nailer
last things first, give it about 6 drops of oil before use in the morning and again after lunch. then try going to Bostitch.com and downloading a manual. the plug might be the air fitting that you need to connect it to a hose. Let me know if you need more help.
Posted on Dec 05, 2009
Support manuals and diagrams
Im guessinga the compressor hasand no pressure. Its probably burnt up. Those are single cylinder oil less compressors ment for momentary use only. Best thing to do is get another one.
Nov 22, 2013 | Stanley STA-J45C09 450 Watt Jump Starter...
I have a Stanley Bostitch CAP2000P-OF Air Compressor. It runs constantly and won't reach the shutoff pressure. It will build some pressure. When I turn it off, I dont hear any leaks.
Jim:
There is a leak somewhere... Use a soapy solution at the air tube from the compressor head to the tank (both ends) and at all air hose connections. The bubbles will tell you where the leak is and you can repair the connections from there...
Aug 17, 2013 | Stanley Bostitch CAP2000P-OF 2 HP Peak 6...
Stanley Bostitch compressor cpack model runs and runs but won't fill tank.
check for any air leaks and fix as needed. then look for oil coming from cylinder heads , if oil is coming from heads you have blown head gaskets ,it wont build pressure like this. you might also check the pop off valve to be blown open. push the pin in and see if air starts to build up then. If so get a new valve.also check the drain valve under the tank and make sure its closed.
Apr 17, 2013 | Air Tools & Compressors
Runs all the time. Why?
The pressure switch should cut off the compressor when cut-out pressure is reached. If however, there is a leak, or the reed valves /gaskets in the head/piston are faulty, the pressure will not build up enough to shut off. With the compressor running, spray soapy water on all fittings including around the head and drain valve. If no leak is found and pressure only builds to less than 50psi suspect reed valves. Parts are low in price and available from various on line stores including www.toolpartsdirect.com Good luck
Oct 15, 2011 | Stanley Bostitch CWC200ST 3HP Oil Lube...
VALVE PLATE ASSEMLY BROKE CANT FINE ONE PART # A64010 FOUND ONE WITH #A640050 WILL THIS ONE WORK
The part #A640050 works on models CAP2040P-OF Type 0 and CAP60P-OF Type 0. If you know what model you have I can look it up for you or you can look it up on servicenet.dewalt.com
Stanley Tool Works (who owns Bostitch) just merged with Black and Decker (who owns DeWalt) so you can find all the Bostitch parts breakdowns at the same site now.
Jul 17, 2011 | Stanley Air Tools & Compressors
On a Bostitch CAP60P-OF air compressor I can get 120 PSI easily but get little or no air pressure on the the hose side. Can't even run a stapler.
Jan 22, 2011 | Stanley Air Tools & Compressors
I purchased a Stanley Bostitch N80 framing nailer from Ebay and would like to have a manual for it. How can I get one? It has a plug out of the back of it and wondered what the plug is for. Also how to...
Dec 04, 2009 | Stanley Bostitch N80CB Coil Framing Nailer
Aug 29, 2009 | Air Tools & Compressors
Bostitch Framing Nailer fails in colder weather
the prblem may lie with the oil that you are using
[too thick] or the guide is worn
Nov 17, 2008 | Stanley Bostitch N88rh Framing Nailer...
Stanley FactoryReconditioned Bostitch UCAP2060P 105 Amp 2 Horsepower 6 Gallon OilFree Pancake Compressor Logo
718 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
