Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer
Duet Dryer How do I get to the door switch????
  • 172 Answers
Hi kroeter,
It is possible to reach the door switch by removing the bottom front plate on the dryer. You will see it above the right side. Before you reach into this section please make sure to unplug your dryer. If you need full access to the switch you will need to remove the top then the console then remove the entire front. You will need some torx screwdrivers. Start by removing the torx screws on the back top, then the top will slide back and you can remove it. Underneath that you will see the top of the console on the front, remove the screws in the console and lift it to remove. then you will be to the top of the door section again you will see torx screws, remove and lift the door section and you will be to the door switch. Good luck and I hope this will FixYa.
Mike Anderson
Posted on Jun 03, 2008
Dryer has no power. I think it has something to do with the door and the door switch
you are probably right. try pressing in door switch with screwdriver and pushing start, does it run? if not remove switch jump across door switch does it run? if so replace switch or just leave bypassed and tape up well.
Mar 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Won't start, keeps beeping when i push start.
The door switch has gone bad. Replace door switch and you should be good to go.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I need to replace a door switch on my Whirlpool Duet dryer. How?!
look toward the bottom the screws are recessed upward to hide them then it should open up like a car hood and there are spring clips at the top
Oct 31, 2009 | Whirlpool GEW9250P Electric Dryer
Lights are on but Dryer will not power on. It is a Whirlpool Duet Dryer. I think it has something to do with the electronics?
Check to see if the door switch is working. Some times the switch activator located inside the door is broken off. Or the switch does not click when you push on it.
Oct 20, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
I looked for door switch kit and some descriptions say for stacking...i don't need that and have duet model 9200 in white. want both doors to open in opposite diections. do i need to buy kits?
ummm.. you can only reverse the door opening in oyour dryer, your washer CANNOT be switched it only opens to the left. the dryer can be switched and the "hine kit" if applicable, only contains a new peicw of trim to cover the exposed trim after revesing the door( the catches are on top and bottom no need to reverse them)
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Door won't latch, interior light stays on, dryer will not start
it appears that someone bent the door or the hinge. that is my first guess.
Sep 22, 2008 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool Duet GEW9200LQ0 Dryer
can oyu oppen the door nad physically push in on the door switch( little grey switch atop the door opening). do you hear it clicking on/off??? if not you have a bad door switch.
Mar 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door reversal for Whirlpool Duet
there is no reversing the door on the washer. the door on the dryer can be reversed and with the execption of a few of the earlier models no kit is required(even then was just a trim kit). is switching theposition of the 2 appliances an option?? as far as wsher vibrating through house heres a new product receiving great response http://www.keshakeaway.com/servlet/StoreFront
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Open Questions:
See all Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Questions
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Gas Dryer Logo
130 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
