Question about Whirlpool Ovens
When I turn the oven to 400 degrees for instance the temperature doesn't go to 400 degrees and the top element is hot, not super hot and doesn't get red. It is a Whirlpool Gols, Acubake system. Model GLP85800 and Selial no IMR1759501
  • 3 more comments
  • merkel_linda Oct 14, 2010
    How do I check the oven temp. circuit or where do I check it.
    How do I check the onen temp circuit
    Thanks for the reply but I don't have a manual so how to we check the oven temp sensor circuit?
    Thank you so much for your help. Now we know what we are looking for.
    Yes it was but when I order the part is it coming from the USA
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 14, 2010
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
Nov 30, 2012 | Jenn-Air Ovens
Top element doesn't get red hot on bake but does on broil is my controler bad
The top element (broil element) will come on when you put it in bake only to help the oven temp get to the desired setting. If your temperature is reaching the right degrees you shouldn't have a problem.
Nov 02, 2010 | Kenmore Ovens
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Built in oven won't get hot
hello there
Usually, when an oven won't heat up or bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. Now if the oven It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem
Hope thisis very helpful for you
Best regards Michael .
Mar 08, 2010 | Ovens
Oven doesn't go on.
Hi.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
If the part that is not heating is only one element, then you may need to replace the element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
In this case, selecting only baking or only broiling (depending on what element is faulty), the oven will work normally.
If the oven is a gas oven, then you have no element. In that case if the oven burners are working, replace the temperature sensor.
If replacing the temperature sensor does not help, then replace the oven electronic control.
Mar 04, 2010 | GE Ovens
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
Oven will not heat.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jun 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Oven Doesn't Reach Set Temperature
Check the element for burns/wholes this was problem for our.  Easy fix and part is about 35 to 40 dollars.
Nov 16, 2006 | Thermador SC272T Electric Double Oven
Ovens Logo
127 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
