Question about Refrigerators
Electrolux Refrigerator PLHS69EESS2 Actuator arm broke. How do I replace it
First, remove the drain tray (it snaps out) Next remove the three screws behind the tray and carefully lift the panel up and out. There is a short control wire connecting the panel to the refrigerator, remove the water hose from the outlet hole and remove the ice and water module.
Click on the link below to order a replacement actuator arm for your Electrolux PLHS69EESS2 Refrigerator:
http://midwestapplianceparts.com/refrigerator-freezer-65/frigidaire-refrigerator-parts-355/frigidaire-water-actuator-arms-1267/frigidaire-refrigerator-water-actuator-arm-6818.html
Posted on Oct 14, 2010
Not sure that I am replacing the ribbon cable correctly after removing dispenser actuator
It is. Did you purchase a new part or are you installing the same part as before with other new parts? The manufacturer may have updated the design within the recent months or past year. Have you tried contacting Electrolux directly at 1-877-435-3287?
Sep 19, 2012 | Electrolux EI26SS55GS Stainless Steel ...
I have a frig/electrolux gallery series dishwasher: model GLD2445RFC0 serial # TH72896159. On the ceiling of the dishwasher is a gray plastic arm that snap onto a round gray disc that screws into the...
If you go to searspartsdirect.com and type in 154607802 for the part #, I'm pretty sure that's what you are looking for. I broke the exact same part and it's what my husband ordered as a replacement.
Nov 14, 2010 | Electrolux Dishwashers
Trunk pull down motor stuck in up position
Two things it could be , the striker motor needs replacing or the actuator on the latch is bad or damaged and needs replacing.. most common is the actuator due its a plastic very easily broken. its about the size of a quarter bolted to the latch and has a little 2 mm arm coming off of it that get broke off all the time.
Good luck
Oct 16, 2010 | 1993 Cadillac Seville
Our side by side electrolux refrigerator will not disperse cubed ice, only crushed. everything else works fine. Model number PRLS267ZAB8
Pull the ice drawer out and look for the small, metal "arm" that sticks out of the back of the outside of the drawer. Empty all the ice out and make sure this arm swivels freely. Sometimes it can get stuck.
Aug 29, 2010 | Electrolux Icon Professional Ice Maker...
Broke off the ice maker shut off arm. want to
Hi. Go to the site called sears parts direct. Enter the model number and see an excellent parts diagram. Order the part and u will have it in a couple of days. J.
Jul 30, 2010 | Amana ARB8057CSL Bottom Freezer...
How do I shut it off, going on a trip. Ice maker swing arm is broke, it just flops. Thanks
Without that swing arm, the only way you can turn the ice maker off is to remove it from the freezer, or of course replace a new swing arm.
I would also highly advise turning the water off to the refrigerator. this is good advice for anyone leaving their home for a while, whether or not you have a problem with your icemaker or water dispenser system.
Visit my website for service or to ask general refrigerator questions: www.FixMyFridge.net
Mar 17, 2010 | Amana ABB1927DE Bottom Freezer...
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Amana ARB8057CSR Bottom Freezer Ice Maker Arm is broken & stuck
If water still continues going to the Ice Maker unplug the pair of wires on the back of the refrigerator that send water up to the ice maker. Now I see I am a little late answering your post, because I just happened to run across it. I was not here when you first posted the problem. Just let me know if you still need help, Thanks Sea Breeze
seabreezehvac@yahoo.com
Dec 18, 2008 | Amana ARB8057CSR Bottom Freezer...
Kenmore/Fridgedaire refrigerator ice actuator replacement
hi thanks for the question are you talking about the arm to stop the ice making if so you can just put back in clips on the front of ice maker and at back thanks the appliance doc
Sep 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
197 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
