Question about Whirlpool Kitchen Ranges
I have a Whirlpool SF362LXSB gas range with error code 600d. Does anyone know what this code means? Thanks, rich.
SOURCE: error code AF Whirlpool cabrio dryer
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
Posted on Jan 10, 2008
Coldcut
  • 1554 Answers
SOURCE: Whirlpool AWM 8103/1 error FP
it looks like you have a clog filter or pump issue.
take a look at this forum
http://www.howtomendit.com/answers.php?id=53072
Posted on Feb 25, 2008
SOURCE: Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Posted on Sep 16, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool Gas Range E2 F3
Bake range over temperature, replacing the oven sensor is the easiest and most common solution for this problem.(w10181986) heres the part number
Posted on Nov 23, 2008
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Posted on Nov 24, 2008
I am getting Error Code F2: E1 What does that mean?
More information needed here: What type of range (electric, gas)? What brand and model number? Every manufacturer uses different error codes.
Mar 12, 2015 | Kitchen Ranges
F1E1 code on whirlpool gold 30" freestanding gas
The E1-F1 error code means that the oven control board has detected a error within the board itself and the control needs to be replaced. The error code can be cleared by pushing the cancel/off button and if it returns shortly thereafter the control defeintly has a defect and should be replaced.
The part number for the control board is W10157245 itcould purchase it at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
GENE-->-->
Sep 17, 2011 | Whirlpool GFG471LVS Stainless Steel Gas...
Error code EO -F2- Any one know what this means
Ledgestone Technologies has replacement keypads for NO LONGER AVAILABLE Whirlpool and Kitchenaid models. Each one comes with a new ribbon cable and 2 year warranty.
Contact FixYourBoard.com for more information!
512-355-1108 info@fixyourboard.com
May 29, 2010 | Whirlpool RBS275PD Electric Single Oven
F2 code on my whirlpool stove buttons not working.
The F2 could mean a timer/control has detected a stuck/shorted keypad. Depending on the model number though it could also mean a shorted oven temperature sensor.
In the event it is a stuck keypad detected, the timer or keypad will need to be replaced. You should first attempt to reset the breaker or unplug the range for a couple of minutes to see if that resolves the error code.
If it is the model that uses F2 as the shorted sensor code, you`ll need to replace the oven sensor, there`s no way around that one.
If you can provide a model number by replying to this post I could try and be more specific, as right now I can only generalize with the most common F2 error codes meaning for Whirlpool manufactured ranges/ovens.
Hope that help`s, let me know.
Good luck.
macmarkus :)
Dec 06, 2009 | Whirlpool 30" Freestanding Gas Range -...
I have a Whirlpool Super Capacity 465 range and received the error messages E4 F3. What does this mean?
if you call me @ 570 263 0077 i will check my fault code list and let you know what those codes meam thanks JOHN
Nov 08, 2009 | Whirlpool GR460 Electric Kitchen Range
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Range displays e2 f1 and beeps every so often
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool Gas Oven
The F1, E2 codes mean you have UL ac-dc errors. This means you need to replace the control.
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
Kitchen Ranges Logo
393 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
