Question about HHB BurnIt CDR830 CD Recorder
Hi there, when recording analogue from mixer to HHB Burner 830 the blank cd does not read properly, and records blank even thou the connections are in the right ins and out (phono to phono) And the input source is going via the indicators and i have plugged in a pair of headphones, so i can hear the source coming through. Presently it's stuck on REPAIR !! And now it's is saying CHECK DISC, then goes on to say NEW DISC !! And even thou something looks like it has been written to the disc it still states NEW DISC. Please can you help ,many thanks joe.
  • HHB Master
  • 5,484 Answers
I can only assume that it's not changing the analogue signal into a format suitable for transferring to a CD. Check the recording settings. Make certain the signal is being converted to say a WAV format or MP3 etc.
Posted on May 03, 2017
aravan
  • 27 Answers
SOURCE: hhb cd recorder
at the time of burning to avoid this problem select multisession option in nero:
Posted on Sep 30, 2008
SOURCE: HHB 850 needs repair
You can contact HHB service team on 020 8962 5000. Or visit their web site and go to support and complete an equipment repair form and they'l get back to you. You can also email the engineers whose names are listed in the contact section. Web site is http://www.hhb.co.uk/hhb/uk/support. Hope it helps
Posted on Feb 05, 2009
  • 99 Answers
SOURCE: Noise / Hum in recordings
hi, i once had the same problem with a kenwood cassette deck. it would play pre-recorded tapes perfectly but when it came to recording from another source i would get an annoying hum when playing back the recording, the fault turned out to be a faulty earth connection on the phono connectors on the rear, they were dry jointed and once resoldered the unit worked and the recordings were perfect. maybe you have the same problem? hope this helps?
Posted on Feb 21, 2009
davesoucy
  • 148 Answers
SOURCE: Records entire church service & indicates time
A laser beam on most (nor all) machine got a ''fixed'' lifetime. After some periode, the light beam get weaker and problem starts. First step would be to make the head clean, i do it myself with Qtip and alcohol make sure the eye is crystal clear, without any imperfection on it. Some times accessing the carrier is not easy, i'm not a fan of auto cleaning disc anyway. So after 2-3 or 4 years, and normal and hours are done with the machine, its normal that problems appear. Before you ask, its usually not economical to replace and ''tune'' a new laser unit. Also, a dvd recorder with hard drive would be a good investement. Look for brand name like pioneer...
Ciao, Dave.
Posted on Oct 08, 2009
dunnbiker
  • 8546 Answers
SOURCE: can't finalize after recording, disc error
So are they always CD-RW?
I have a Pioneer PD509 which is a spittin' image of the HHB CDR830 but tied down to use CD-Audio discs only.
My experiece with Rewriteable Media has been that they don't hold up to multiple uses. I used them to make quick 'n' dirty dubs of cassette audio then worked it into a polished copy with proper track marks and sweetening later for copy over to a CD-RA. After a few passes I'd start getting audible problems when copying off the -RW's, so I routinely just use them about 5 times. With two DVD players and a Blu-Ray I sometimes get through the errors on one of them for one final digital copy and then I can them.
BTW: you may want to try the failing disc in a DVD player. Mine will play through an unfinalized CD but can't cue up to anything. So if the recording is vital you might retrieve it that way. Just remember to pause the Recorder at the end of the last cut you want because the DVD will just crash right into the old data without changing track numbers or any warning.
Posted on Mar 04, 2010
Hi, I have an HHB Burn-It CDR 830. Whenever I'm recording, along about the 5th track in- the player starts to fuzz out. The time stutters/freezes momentarily, and then continues normally for a while...
If it's always around the same physical location on a given CD it would have to be a physical problem with the transport, not the lens.
Esoteric but comprehensive advice....
http://www.repairfaq.org/sam/cdfaq.htm
Sep 20, 2011 | HHB BurnIt CDR830 CD Recorder
Hi , My cdr 830 stopped recording at maximum fidelity, and most recently all data disappears upon finalization, the prompt reading "new disc" after recording a whole 70 plus cd. Frustrating...
I can't speak to the hardware issues that might be at play here but I would advise you to retain the 'bad' recordings. I've copied unfinalized CD's from an old DVD player. It will read the CD but you won't be able to manuever around the tracks. As I recall, the track marks will still be there.
I don't know what you mean by 'maximum fidelity'. The CDR records at the CD standard of 44.1kHz. Digital is all ones and nones. Just data. If it is written correctly or with tolerable errors the ADC of the player (ANY player) turns it all into music.
Mar 02, 2011 | HHB BurnIt CDR830 CD Recorder
What does pma rec mean on the hhb cbr 830 ? it just stops recording
The recorder is writing TOC data to the disc's PMA (Program Memory Area). Never turn off the power while this display is
showing.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
Aug 13, 2010 | HHB BurnIt CDR830 CD Recorder
User manual
You can get it at www.manualsonline.com,www.manualnguide.com or at their website.
thanks and good luck
Jun 04, 2010 | HHB 830 Plus CD Recorder CD Player
Pause/resume function in analogue, manual recording mode
This player has essentially the same guts as my Pioneer PDR-509, so this is what it means...
'Repair' means the player lost power in mid-recording without commiting the track memory to a table of contents. It would likely take up to 40 minutes for the player to reconstruct it from the disk.
There is NO reason the player need be turned off (if that's where it took you) for a track pause.
Just press Pause, flip the LP over and hit Play or Pause again when you wish to continue recording.
Perhaps you don't know how to Finalize the disc either. It's not that intuitive. Press Finalize, after a while it will display a time, like 4:07. That means how long it will take to do the operation. Now press Pause and it will count down to 0:00 and be done. Then you can play it on any other CD player.
Feb 14, 2010 | HHB 830 Plus CD Recorder CD Player
Anytime I try to record with my HHD BurnIT cdr 830, the red record light will only be bleeping and the time counter will not work as well. And there will be nothing recorded on the cd.
Just a guess, but did you ever try to hit the record a second time once you're all set up to start? The first press of the record button places the machine in record/pause mode after it calibrates itself to the disc.
Jan 19, 2010 | HHB BurnIt CDR830 CD Recorder
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
Does not reconize blank CDs
this is cd reading problem so open ur cpu and see the bus connection in between motherboard to cd drive....
and replace the bus.....
Jun 02, 2008 | HHB CDR850 CD Recorder
HHB CDR-850 Professional loading problem
I had the same problem with mine. The manual says to unplug it from the power and plug back in. That did'nt seem to correct anything. I also was having an issue with recording. It would'nt record data for tracks and recording would scramble. I had this burner for 10 years and loved it untill last night when it crapped out on me completely. I am VERY disappointed!
Mar 30, 2008 | HHB CDR850 CD Recorder
Recording
Connect the analogue inouts of the recorder to the monitor or tape outputs on the mixer.
Nov 27, 2007 | Denon DN-C550R 2-Disc CD Recorder
HHB BurnIt CDR830 CD Recorder Logo
76 people viewed this question
Top HHB Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
