Question about GE Spacemaker Washer and Dryer Electric Laundry Center
Hi! I have a GE Spacemaker Laundry Washer/ Dryer. Really weird...when I wash whites they come out with blotches of stain all over??? I've tried bleaching them and the stains don't come out?? It looks like spotches of oil?? It has ruined everything white that I own?? Hope you can help???
  • 4,070 Answers
It probably is oil coming from the transmission which is under the agitator. If you can remove the agitator you may find oil at the bottom where the clothes can get under the edge of the agitator. Here is a diagram of the transmission.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FLSE72GCSA/1428/0152000/Y2705243/00007?blt=06&prst=&shdMod=
Posted on Oct 14, 2010
Ge spacemaker laundry dryer does not heat
All dryers have states to control heat GE has a safty stat that is comon problem small round stat at top after removing lid check with ohms meter with wire unpluged if no continuity changed then check venting of dryer inside and out improper venting will cause dryer to over heat
heat element is the next go to same check but must take dryer apart more send model Number we can give you a diagram and location of everthing you will need
Jan 30, 2013 | GE Spacemaker Washer and Dryer Electric...
The dryer timer stopped working
Is that a temperature senor in the GE spacemaker Laundry dryer? My dryer stops spinning when it gets too hot. After it cools down, it will spin and dry again.
Jan 05, 2013 | GE WSM2700W Unitized Spacemaker Washer and...
1989 (?) GE Spacemaker washer in a park model trailer has a cracked plastic air pressure tank. No model # on washer, how do i get parts.
You do need the model number to order parts...typically on a stacked unit the model number is inside the dryer door
Sep 08, 2011 | GE Spacemaker Washer and Dryer Electric...
GE Spacemaker Washer Tan does not spin or drain
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | GE Spacemaker Washer and Dryer Electric...
I am looking for a manual for my GE spacemaker laundry
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 23, 2011 | GE Spacemaker Washer and Dryer Electric...
Does anyone have the schematics or manual for a GE Spacemaker WSM2420TCAWW Stackable Washer and Dryer.
I have this model with model#WSM2420TCAWW tag inside the dryer however the use and care guide and manual that came with it has Model#WSM2420S on it. Try searching this. If you dont have any luck I can send you a copy with your e-mail. Good luck dc
Oct 24, 2010 | GE Spacemaker Washer and Dryer Electric...
Ge Spacemaker Laundry the washer knob popped out
take knob off again and look at the stem where the knob goes does it have a round side and a flat side? if so the knob will have the same profile thats the way it goes on
Sep 09, 2009 | GE Spacemaker Washer and Dryer Electric...
GE WSM2480TBAW Spacemaker Laundry, Won't Drain or Spin
you need to remove the slanted panel between the washer and the dryer. There will be 2 screws holding the top of the washer to the cabinet. Locate the screws on the back edge of the washer top along with the 2 brackets that hold the top.
Once the brackets have been removed, the washer top panel will pull toward you and lift off of the cabinet. You will be able to see the lid switch and test it. If you are testing the lid switch for continuity, remamber to activate the switch while testing. If the switch shows an open circuit, replace the switch.
Please let me know if this hhelps you at all or if I can assist you further.
Thanks
Vic
Jul 23, 2009 | GE Spacemaker Washer and Dryer Electric...
GE spacemaker dryer won't start
Have you tried keepin the dryer door open, depressing the safety switch which enables the dryer to work when it is closed, and then turn on the dryer to see if it turns at all? Sometimes its the smallest things that cause these problems. That switch that gets pressed when the door closes, sometimes malfunctions. Sometimes the door of the dryer gets out of whack and doesnt really make contact with the switch enough to trigger the flow of electricity.
Jan 01, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
