Question about Intel Desktop Board D815EEA2 Motherboard
D815 led and etc pins
I have a d815 but i dont know how to hook up the pwr hdd and reset led
    President:
  • 2,351 Answers
Looking at page 85 in you're user manual. The 15 pin jumper block. Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G. If you need the manual you can download it from this link.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
Included below is a small pic.
d815 led and etc pins - e8e7d5a.jpg Good Luck!
Have more questions? Please feel free to ask.
Mike
Posted on Jun 02, 2008
I just installed my motherboard samsung harappa-4 on new casing, but i don't know how to connect cable for power switch,power led,hdd led, and reset, please give me solution, thankyou very much
LOOK FOR THE FRONT PANEL PIN HEADER.
IT MUST BE SOMEWHERE BY THE EDGE OF THE MB.
THERE ARE MARKINGS LIKE HDD LED, PWR SW ETC.
HOPE THIS HELPS.
Apr 13, 2010 | Computers & Internet
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
Unpluged HDD LED PWR S/W and PWR LED for board
it's usually written in fine print beside pins. Failing that get the manual which tells you
Feb 26, 2010 | E-Machines T3958 (827103050974) PC Desktop
I need assistance with the front panel cables (Power, HDD, Reset etc)
On your motherboard power is setup like so:
10 9 8 7 6 (no pin on 6)
1 2 3 4 5
1- HD_LED_P
2- HD_LED_N
3- RST_SW_N
4- RST_SW_P
5- RSVD
6- No pin
7- PWR_SW_N
8- PWR_SW_P
9- FP PWR/SLP
10- FP PWR/SLP
you have 5 connectors from the chassis' front (with cable colors):
-P LED (white)
+P LED (green)
HDD LED (yellow/white)
RESET (white/blue)
POWER (orange/white)
You just insert cables according to these nos. Do this job carefully that's why i am giving you full details about cable and its colors.
Regards
Ashly
Feb 24, 2010 | Computers & Internet
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Connecting the case to my motherboard
Pin arrangment is Industry Standard Architecture.....
pwr led pwr sw N/C
X X X X O
X X X X O
hdd rst N/C
translated this is top row left to right ...... power led, power switch no connection
Bottom row is left to right........ hard drive, reset, no connection
Note: not all computer cases have a reset button, also the connectors for power led and hard drive produce a light, if the light does not show, power off the pc swithc the cable rooun 180deg on the connector pins and reconnect.
Dec 04, 2008 | Computers & Internet
Where to hookup front panel (PIII-3754LMR - AMPTRON)
check arrow hok up the procesor from where u see arrow after removing fan etc .
Sep 29, 2008 | Amptron PM-9100A Motherboard
Motherboard
To download you're manual for the D815EEA2, please click the link below.
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Good Luck!
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Intel Desktop Board D815EEA2 Motherboard Logo
1,825 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
