Question about Hiro (H50069) Wireless Adapter
Can ant one help me, I need to configure a shared progam in my router
Please provide more details
Posted on Oct 14, 2010
Please give me more information
Where to connect router on modem
Your modem should have an rj45 ethernet port. Connect your router with an ethernet cable to the modem. You will need to configure your modem and router to work properly. Once everything is configured, you will be able to share your internet connection through your router to all attached devices. For more information, please provide your exact make and model numbers for your router and modem and always remember, Google is a great source for information. Hope this helps.
Dec 04, 2013 | Motorola Computers & Internet
Device asks for passphrase or pin, what is this,(zoom 3g router)
The passphrase is used to generate the encryption code in the router's wireless configuration.
For instructions to configure the router's wireless settings ant to configure the wireless card in the laptop/computer - please click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 03, 2010 | Zoom Computers & Internet
I have 3 PCs -> 1st have 1 Ethernet port. (this PC have a laser printer, dual core processor, BSNL board band) -> 2nd have 2 Ethernet port. (1 is Motherboard inbuilt & other is connected as NIC...
http://www.geekgirls.com/windowsxp_home_network.htm
or
http://windowshelp.microsoft.com/Windows/en-US/help/76174f4a-7522-425a-9424-324dd299265e1033.mspx
or
http://video.google.com/videoplay?docid=-4885804885278005452#
Sep 20, 2009 | ASUS P5VD2-MX SE Motherboard
MSI
The Pre-shared key is used to setup encryption on wireless routers.
The latest strongest encryption methods used is Wi-Fi Protected Access (WPA and WPA2).
The wireless router is configured with WAP or WAP2, and the computer's wireless card is configured with the router's WAP or WAP2 encryption. The wireless router will now allow communication with the computer's wireless card, data transmitted between the router and computer is encrypted and therefore protected from unauthorized access.
Sep 08, 2009 | MSI Wireless-G RG54G3 Router
Configure wrt54g2
IF you mean "File Sharing" as in your own network of PC's on your network, then all you need to do is turn off sharing option within windows. Your router will not set sharing your folders, drives, printers, etc.
Check your windows setting in "Networks", then "Sharing" and set the appropriate options for your needs.
Hope that helps.
RJ
Apr 15, 2009 | Linksys Wireless-G WRT54G Router
Want to know the pre shared key
If you don't know your pre shared key or forgotten it. You need to access the configuration page of your router and create a new network name and a sign a new network key or pre shared key. Create the profile of your SSID/Wireless network connetion under wireless settings.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Access denied to network to laptop
Disable all firewalls, both on laptop and on computer that shares the printer.
Ensure that laptop and desktop sharing the printer are both on same Domain or Workgroup.
If this does not fix it, call back the Geeks and thell them to acces the router configuration, and configure router internal firewall.
Put both laptop IP and computer sharing printer IP in the range of thrusted IP on router settings.
Sep 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
How To Configure FM114P or FR114P for an Internet Connection and Printer Sharing
There are three steps: 1. Configuring the router for Internet access 2. Installing and configuring the print server 3. Adding the printer to the Windows configuration To Configure the Router for Internet Access 1. Connect the modem to the router's Internet port and your LAN computers to the router's LAN ports. 2. Shut down your LAN computers. (Power them off.) 3. Power off the router. 4. Power off the modem. 5. Power on the modem. 6. Power on the router. 7. Start the LAN computers. 8. Enter 192.168.0.1 in a Web browser's address. 9. Type username and password (by default admin and password). 10. Click Setup Wizard to configure the router's Internet access. To Install and Configure the Print Server 1. Install the Printer Server Driver program on a computer. 2. After installation, make sure to select the Run Print Port Setup now box. 3. Click Finish. Print Port Setup runs, showing you the firewall and the printer. 4. Click Port 1. 5. Click Add. A pop-up message says whether a port was created, then the Add Printer wizard starts. To Add a Printer With the Windows Add Printer Wizard 1. Continuing from the last section (or clicking Start > Settings > Printers > Add Printer), click Next. 2. Select Network Printer, and click Next. 3. Click Next again (leaving the port as LPT1). 4. Select the manufacturer and printer model of your printer. (If your printer does not appear, you need to get the CD or floppy that came with the printer, and use Have Disk to specify the file location. Note that it is looking for a file that ends with .inf.) 5. Click Next. 6. Change the printer name to something users on your LAN will recognize easily. 7. If prompted by the Add Printer Wizard about sharing: DO NOT enable sharing! Now test the printer. Other information about Windows configuration is available in Windows help in the article "To connect to a printer on a network".
Feb 19, 2006 | NetGear FR114P Router
Feb 19, 2006 | NetGear FM114P Cable/DSL ProSafe 802.11b...
Computers & Internet Logo
37 people viewed this question
Top Hiro Computers & Internet Experts
Prashant M
Prashant M
Are you a Hiro Computer and Internet Expert? Answer questions, earn points and help others
