Question about Denon AVR-2807 Receiver
DEnon AVR 2807 not giving desired output
I have denon AVR 2807. The unit malfunctioned due to surge of electricioty at home due to short circuit. Volume of all channels is very low and the sound is muddy and bad. Tuner, DVD all r working simultaneously. Can anybody suggest the remedy and cost of repair
You may be able to unplug the unit. Then turn it back on while pressing two buttons on the front of the unit. You will have to find out which two buttons they are, it can't just be any two. What you will be doing to the unit is resetting the micoprossing of the unit. When you do this the unit will flash, reset itself, you the release the buttons and your good as new. I have done this with a couple different reciever and it is a easy fix.
Posted on Sep 28, 2008
My denon avr-2807 sound is studdering as the
sounds like a loose cable to me probably component. trace and replace.
Chris B
PHTBA
Feb 18, 2010 | Denon AVR-2807 Receiver
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
Can't get the sound to work on my TV using the Denon AVR-2807
In the 2807 the HDMI out is a video out only. Audio is not processed through the HDMI output.
If you are using speakers it is best to adjust the playback modes to stereo if you are annoyed with surround sound modes.
Please comment if I helped.
Oct 04, 2009 | Denon AVR-2807 Receiver
Want to put set of outside polk speakers to Denon avr 2807
Do you have outputs for both A and B speakers? If so you can easily hook the outside speakers to the B outputs.
Jun 16, 2009 | Denon AVR-2807 Receiver
Condition on HDMI input when Denon AVR-2807 switched off
hello if you know this spitter conduct voltage and its feed from main device and when you connect another it send it ground you have to do this chech with a voltmeter in the hdmi splitter output is not dc present if so change it cause is not blocking dc current saludos
Dec 04, 2008 | Denon AVR-2807 Receiver
Operating my ipod docking station
Absolutely!
Keyword(Read the instruction and follow it step-by-step.) Well,if you do,you wouldn't be asking for help,cause you want a 50+ pages Denon manual instruction to be concise to few paragraphs so you could move on with your life-:o)
Okay.only this time!
Denon ipod docking station comes with a power plug and a set of cable which you need to connect behind the Denon AVR-2807 receiver which is under an INPUT LABEL for IPOD only(not going to give it away,you will find it!)
Now,of course you could use HDMI......but,the quickest way to view your video(on screen menu) will be using a composite(RCA) video cable to connect from the Video output(yellow color) from the receiver to the TV composite video input.Turn on your IPOD,and you are ready to see the on screen manual.
Hey,this is just a lazy way to start you off if tomorrow night you have a date;otherwise,set it up properly by using the instruction!
Cheers,
solutiondoct
Oct 18, 2008 | Denon AVR-2807 Receiver
No output from unit (denon avr2807)
El amplificador de audio IC esta dañado por eso no existe audio hay que remplazarlo.
Mar 31, 2008 | Denon AVR-2807 Receiver
What to use for Audio-out on Denon AVR-2807?
Hi Karmor
Use the Tape Out(rec) connections on the Denon. If that model has a rec out selector, then be sure to select phono as well. All sweet and ready to rip them files!!
regards
Graeme
Mar 15, 2008 | Denon AVR-2807 Receiver
Loss of sound on the Denon AVR 2807 a/v surround receiver when I turn on and off lights in my house
Finally the problem was with the HDMI cable. When I pushed it in on the TV set the problem disappeared. It seems the connections must be quite firm on the HDMI cables otherwise anything may interfere to the sound.
Jan 06, 2008 | Denon AVR-2807 Receiver
Denon AVR-2807 Receiver Logo
232 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
