Question about Sunbeam 2350 Heritage Series Mixer
I have a Sunbeam mixmaster de luxe Model x12. It is about 60 years old. Can it be repaired? If so were are you? I am in Herts England Sandra Dann
SOURCE: 2359, 2360 sunbeam mixmaster
It is the worm gears attached to the front of the motor in the housing I had the same problem on the heritage series. The parts are plastic so inevtiably they wear out.
Posted on Feb 07, 2008
  • 4 Answers
SOURCE: Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Posted on Dec 16, 2008
SOURCE: Sunbeam mixmaster jammed, will not
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
Posted on May 06, 2009
rylee_smith
  • 8619 Answers
SOURCE: Sunbeam Heritage Mixmaster Won't Tilt
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 12, 2009
SOURCE: After dough hooks for my sunbeam mixmaster model no. mx-ac
Use this link. I'd been looking for years and I found them here. http://buyitnow64.stores.yahoo.net/sustmidoho.html
My sunbeam mixmaster is about 40 years old and suddenly stopped working
The running capacitor finally died. I used to be their factory service tech. You can change it easily by removing the back knob and the handle. The screws are under the silver buttons. The capacitor looks like a 3/4 x 1 1/4' tube with a small nib sticking out each end.
Dec 26, 2012 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam Mixmaster... where's the model number?
Lift up the head, should be right by where you insert the blades
Jan 24, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Apr 27, 2009 | Food Mixers
Sunbeam Mixmaster mixer is smoking from the motor or the back are
you fried the motor it is not worth repairing
Dec 08, 2008 | Food Mixers
Model #2366 mixer blade release problem
I found a site that says it has replacement stands for 19.95 plus shipping. You can check it out at http://www.bettervac.com/proddetail.asp?prod=SUN%2D84128&cat=293.
Good Luck
Dan
Oct 08, 2007 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam 2350 Heritage Series Mixer Logo
179 people viewed this question
Top Sunbeam Food Mixers Experts
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
