Question about Honda Black Max 2600 PSI Pressure Washer
My Honda PSI 2600 will not suction the solution?
    Scholar:
  • 100 Answers
1. Make sure that you are using the black quick connect nozzle supplied with your machine. If you have a vario nozzle (turns back and forth to adjust the spray pattern), you are going to want to pull out on the nozzle to get the machine to a low pressure setting.
2. If you still have an issue, take a paper clip, straighten it out and stick it into the hose nipple on the pump where your chemical hose is connected, push in and out a couple times to free up the ball and spring.
3. If it still doesn't work, take the chemical nipple assembly apart, make sure there is a o-ring, ball and spring. If one of these are missing you are going to have to order a chemical injector repair kit. If you have all the parts you can streach out the spring a little and put it back together which should make it work.
Posted on Oct 21, 2010
How can I stop the siphon?
Are you using the black nozzle? Switch to a different nozzle. If you are not using the black nozzle the siphon fitting is bad.
Sep 24, 2014 | Karcher G 2600 XH 2600-PSI Honda Gc190...
Where can I get a rebuild kit for pump?model XR-2600.
remove the pump and throw it away. Buy a better designed pump on eBay. just search your pressure washer model number or the obsolete rebuild kit part number a14292 you'll find the better pump.
Apr 03, 2012 | Honda Black Max 2600 PSI Pressure Washer
Troy bilt 2600 psi when you turn the water on it shoots out through the chemical supply inlet
My chemical supply inlet has a checkball and a spring that keeps pressure in check. There must be debris behind checkball. Easy to check by removing the fitting. If faulty and parts not available, plug fitting and add an aftermarket injector from www.pwmall.com. that you can install when you need it. Good luck
Sep 30, 2011 | Honda Black Max 2600 PSI Pressure Washer
How do you drainoil so you can change the oil in Honda Black Max 2600 pressure washer?
lornaa, you can get a copy of the user manual from this link. It has come directly from the manufacturer.
thanks and good luck
iain
May 04, 2011 | Honda Black Max 2600 PSI Pressure Washer
Honda Black Max 2600 PSI Pressure Washer Logo
172 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
