Question about Altec Lansing BXR1220 2 Speakers
I bought Altec Lansing Speaker System for computers... BXR1220.. It says it has "User gudie and Quick Connect guide" but it only had the Safety instructions and Warranty.... Help
  • 277 Answers
SOURCE: Altec Lansing ATP3 volume control/power know gone bad
hi im familier with this system but i dont excactly remember where are the screws however the opening methods are all alike look for any screws any where on the speaker look behind the net if thereare any if there are gently shove a flat screwdriver and lift out the net then after all the screws are out there is a small slot souronding the speaker gently shove a flat screwdriver in the corner of the speaker untill there is a small gap do the same for all corners there might be another hook in the middle that it good luck do the same
Posted on Apr 17, 2006
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
ginko
  • 19396 Answers
SOURCE: driver/installer
Here is the 221 download page: http://www.altec-lansing.com/product_details_intl.asp?country_code=pk&region=northam&pID=221
cheers
Posted on Feb 16, 2008
Open SKy
  • 619 Answers
SOURCE: installing the wires in the right place
Hello there!
First things first!
http://www.altec-lansing.com/downloads/ACS451_MAN.pdf
Posted on Feb 25, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
7 WIRES , WHAT COLOR GOES TO WHICH PIN? 2 BLACK , 1 GREEN, ONE YELLOW, ONE WHITE, 2 ORANGE, ONE HEAVIER THAT THE OTHER
Hi Jerry
What Model....?
Using a mobile phone camera would have helped in this situation.
Before taking things apart
I'll be very surprised if someone has the same speaker system in bits somewhere
An electronics guy would trace the wire back to it's source to decide what it's being used for.
Good Luck
Review Altec lansing BXR1220 Speakers 8
Altec Lansing Avs300 PC Speakers Sub
Sep 13, 2015 | Altec Lansing Audio Players & Recorders
How do Altec Lansing AVS200W 2-Piece Multimedia Speaker System connect to your computer
Using a regular audio cable with 3.5 mm. connectors at both ends, connect your computer to the speaker from the the headphone jack to the 3.5 mm LINE IN jack on the speaker.
Jul 10, 2014 | Altec Lansing Avs200w 2-piece Multimedia...
I had ordered an altec lansing 1220 speakers from flipkart. While i plugged in the speakers there was no power input to the system....hence it didn't work...when I checked on altec lansing website it...
This speaker is using a USB to draw its power. You can try using other USB ports on the computer or use USB chargers (Apple, HTC, Android phones, etc) to test it, if all else fail then you may need to return it because its defective.
Aug 27, 2011 | Altec Lansing BXR1220 2 Speakers
There is no sound from my speakers altec lansing model bxr1220
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 26, 2011 | Altec Lansing BXR1220 2 Speakers
Can I connect my Altec Lansing ADA745 4.1 speaker system to an Acer AS5745-7247 laptop?
Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
Make the connections as follows
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Altec Lansing ADA745 4 Speakers
BXR 1220 is compatable with onida DFX-5965 DVD Player
It is, as long as you know where to power your Altec Speaker. Since it is USB powered, i think you need to plug it in a USB adapter for AC.
Jan 20, 2011 | Altec Lansing BXR1220 2 Speakers
Connect Altec Lansing ADA745 to HD TV RCA output for home theater
It won't work like this due to this being a computer only speaker system. It requires the drivers to work with a computer & a Home theater does not recognize the format. Sorry.
Feb 25, 2009 | Altec Lansing Multimedia Computer Speakers
I have a speacker system that is a older model I need a copy of the user manual can i aquire this on line. It is a Altec Lansing in motion item and has two flip up speaker and the imput ports on back.
this website has the manual you are looking for. you have to download it to your computer. you should find all you need
safemanuals.com/brand-user-guide-instructions-owner-manual/ALTEC%20LANSING
Jan 02, 2009 | Car Audio & Video
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Altec Lansing BXR1220 2 Speakers Logo
29 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
