Question about MagLite - Mag Charger System 110v (M) Model - RX1019
I have an old rechargable maglite. when I put it on the charger the red charger light does not come on and it will not charge. However if I depress the on button when it is in the charger the red light will come on but it cannot be charged like this. I have a new battery and it happens in both the ac and dc charger so I assume the problem is in the flashlight.
    Problem Solver:
  • 19 Answers
You might try this website, they should be able to answer any questions.
http://www.maglite.com/feedback.asp
Posted on Oct 14, 2010
When I placed my Lithium Ion Battery in the charger it doesn't carge the batter and the red light that's supposed to stay lit while it's charging keeps on blinking on and off.
How old is the battery?
It's very possible that the blinking light is indicating a bad/old battery. These rechargeable batteries after so many cycles lose it's charging capability and the fault system built into the recharging base will indicate by giving you the red light on & off. Energizer rechargeable station is a good example when it detects old or bad batteries.
Nov 08, 2009 | Casio Exilim EX-Z57 Digital Camera
Charger is putting out 13.7 volts but battery does not take a charge
If its the right charger, and connected correctly, then it is probably just time to replace the battery. Try checking out http://www.batteryinternational.com/flashlight-batteries-streamlite---maglite.html for a replacement flashlight battery. Also, I'm not sure exactly what you mean by saying the charger is putting out 13.7 volts, but make sure you aren't using a charger that is too powerful, that can destroy the battery. Check out http://www.batteryinternational.com/battery-chargers-6-volt-battery-chargers.html. You shouldn't use a charger any larger than that. Hope that helps
Jul 10, 2009 | Vector 3 Million Candlepower Rechargeable...
Change bulb light will not turn on
Try getting a new battery, and see if that works.
Jan 01, 2009 | MagLite RX3019 Rechargeable Flashlight...
Rechargeable maglite won't turn on.
I found out the light bulb was bad even though it looked good. Had a fine break in the filament that I couldn't see with my eyes. Pulled the light bulb part way out, put a voltage meter on the two prongs. It showed I had voltage right up to the light bulb which told me the light bulb was bad. Ordered a new one and it works.
Dec 22, 2008 | MagLite - Mag Charger System 110v (M)...
New battery
Charge it for at least 12 hrs before using and run it down every so often to get a complete charge out of it and longer battery life.
GGBMDB
Nov 18, 2008 | MagLite - Mag Charger System 110v (M)...
Rechargeable mag light not working .
when you dropped it you probably knocked the contacts inside out of place. or you broke a soldered connection. if you can take it apart you can most likely fix this yourself. when you remove the front lens assembly there is a retaining clip that you need to remove so you can take the guts out.....please rate this
Sep 02, 2008 | MagLite - Mag Charger System 110v (M)...
Unless you are using your Mag. in extreme dusty, dirty conditions, it is not necessary to take it apart for cleaning. The Mag. is sealed against dirt and moisture. Mags are about the best lite made but always remember; 'Anything man made is subject to fail and usually at the most inconvenient time.' If I knew exactly where you are at in the dissasembly I could help you reassemble it. However, barring that;
Go to; www.maglite.com, they can help you with what ever you need.
Good luck. :)
Jan 26, 2008 | MagLite - Mag Charger System 110v (M)...
Maglite charger
Hold the maglite after 30 min charge if warm means charging , if cold no charging , test the light when so bright means very good.
Dec 25, 2007 | MagLite - Mag Charger System 110v (M)...
Weak beam
8years old.very weak beam no fault to flash halogen lamp . system seems to be not fully charged
Aug 21, 2007 | MagLite - Mag Charger System 110v (M)...
MagLite - Mag Charger System 110v (M) Model - RX1019 Logo
609 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
John Egan
John Egan
David Black
David Black
Level 1 Expert
 steve
steve
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
