How do I load envelopes? I have a Canon MX320 and I just bought it and haven't set up envelopes yet. How do I load the 3 5/8" x 6 1/2" into the machine?
frcs68
  • 1605 Answers
SOURCE: Can't print envelopes
you need to select tray #1, manual feed.
tray #2 is auto feed- 8x11 sheet paper.
Posted on Jan 29, 2009
SOURCE: Printing DL envelope on Canon Pixma iP4600
its not the problem of your way of operation, its the limitation of of the printer.
Posted on Jul 10, 2009
efs_perpends
  • 1996 Answers
SOURCE: Printing #10 envelopes with 5100cn,
You can download the manual for your printer here. You merely need to go to the word processor or program you're printing from and load the addresses and send them to the printer. Try just one as a test to make sure your margins and spacing are set up correctly.
For Dell specs on print media guidelines for your machine, see here. For a blurb about en velope loading, see here. All options here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 10, 2009
  • 987 Answers
SOURCE: canon mx310 all in one
first uninstall the driver then disconnect the USB cable ...reinstll the driver then re-connect the cable ...
Posted on Sep 11, 2009
  • 385 Answers
SOURCE: I AM FACING THIS PROBLEM
HI!The best and easiest way is to put in the document in the document feeder,dial the fax number and press the black start button as the color one will scan the document but not send it and give a error!!Good Luck!
Posted on Dec 09, 2010
How to load envelopes in a canon mg3250 printer
Hi
Please find below a fairly comprehensive guide to using envelopes on your machine
The address is automatically rotated and printed according to the envelope's direction by specifying with the printer driver properly.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif You can only print on envelopes with the computer.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Do not use the following envelopes. They could jam in the machine or cause the machine to malfunction.
- Envelopes with an embossed or treated surface
- Envelopes with a double flap
- Envelopes whose gummed flaps are already moistened and adhesive Prepare envelopes.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Press down on all four corners and edges of the envelopes to flatten them.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the envelopes are curled, hold the opposite corners and gently twist them in the opposite direction.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif If the corner of the envelope flap is folded, flatten it.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image002.gif Use a pen to press the leading edge in the inserting direction flat and sharpen the crease.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif The envelopes may jam in the machine if they are not flat or the edges are not aligned. Make sure that no curl or puff exceeds 0.1 inches (3 mm). Load envelopes.
(1) Open the front cover gently, and extend the paper support.
(2) Use the right paper guide (A) to slide both paper guides all the way out.
(3) Load the envelopes in the center of the front tray WITH THE ADDRESS SIDE FACING DOWN.
The folded flap of the envelope will be faced up on the left side.
Push the envelopes all the way to the back of the front tray.
Up to 5 envelopes can be loaded at once.
(4) Slide the right paper guide (A) to align the paper guides with both sides of the envelopes.
Do not slide the paper guides too hard against the envelopes. The envelopes may not be fed properly.
Do not overload envelopes by stacking until the top of the stack touches the paper guides. (5) Open the output tray extension.
Open the paper output tray.and extend the paper output support.
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Be sure to open the paper output tray when printing. If not open, the machine cannot start printing. After loading envelopes
c:\users\mike\appdata\local\temp\msohtmlclip1\01\clip_image003.gif Select the size and type of the loaded envelopes on the print settings screen of the printer driver. You may find it easier to download the manual from here
Canon PIXMA MG3250
and install it on your desktop for future reference
Cheers
Nov 13, 2014 | Canon PIXMA MG3250 All-in-One Inkjet...
Canon printer MX310 works fine, but I have never used before to print envelopes. Once i set it for a particular envelope, where do I insert the blank envelope. Have tried every conceivable...
canon.gifPrinting an Envelope
For details about how to load an envelope into the printer, see the user's manual.
The procedure for performing envelope printing is as follows:
1. Fold down the envelope flap.
2. When loading the envelope in the rear tray, orient the envelope so that the flap is on the left and the folded surface is facing down.
3. Open the printer driver setup window, and select Envelope from the Media Type list on the Main tab.
4. Click the Page Setup tab, and select Youkei 4, Youkei 6, Comm. Env. #10, or DL Env. for Page Size.
5. Select Landscape for Orientation.
6. Click OK.
When you execute print, the information is printed on the envelope.
Jul 21, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I print an envelope on my Canon MP510?
Envelopes must be fed from the Auto Sheet Feeder. Use either European DL or US Comm. Env. #10-sized envelope.
Important :
  • You need to print from the computer to print on envelopes.
  • Do not use envelopes with embossed or treated surfaces, a double flap, pressure seals, or sticker flaps.
  • Select either DL Env. or Comm. Env. #10 in the printer driver according to the envelope size you are using. If you do not, the address will be printed in the wrong direction.
1 : Retract the Paper Support.
2 : Load the envelope against the Cover Guide (the right side of the Paper Support).
Load with the front face UP and the rear flaps DOWN on the left.
A maximum of 10 envelopes can be loaded at once.
*1 Printing orientation
*2 Make sure the flaps are folded.
Important : Make sure that the Cover Guide is set upright.
3 : Pinch the Paper Guide and slide it against the left side of the envelope.
4 : Press the Paper Feed Switch so that the Auto Sheet Feeder lamp lights up.
5 : Set the Paper Thickness Lever to the right.
In the printer driver, select 'Envelope' in Media Type, and then select 'DL Env'. or 'Comm. Env. #10' in Page Size.
Jun 21, 2011 | Canon PIXMA MP510 All-In-One InkJet...
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
How do I change the ink on the Cannon MX330? I cant find where the cartridge is
I am writing this to enquire in regards to Canon Pixma MX320. I bought a Canon Pixma MX320 about 3 weeks ago, and I have brought it over to overseas. I am wondering if it is possible to change from the general ink cartridge that this particular printer use, which is PG510 and CL511 to another similar ink cartridge, which is PG810 and CL811. This is because, where I am living right now, doesn't have the particular Canon Pixma MX320, but instead Canon Pixma MX328 and MX338. The Canon Pixma MX328 and MX338 uses the PG810 and CL811. So, is it possible to substitute from PG510 to PG810 and CL511 to CL811 for Canon Pixma MX320? Thank you for your help.
Aug 29, 2010 | Canon PIXMA MX330 Multifunction InkJet...
How do I print an envelope from the Canon MP150
  1. Do the following
    Open the paper support and extend the paper support extension.Open the paper output tray. Set the paper thickness lever to the right side for envelopes.Load envelopes in the auto sheet feeder with the print side facing up. Check the printing direction.Set the envelope in the direction of the arrow.Set the envelopes to the right side of the auto sheet feeder.Pinch and slide the paper guide to the envelope's left side .
May 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
How to print envelopes using a Canon i560 printer?
Support site http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9282
if you click on the support and service TAB - and then look for "frequently asked questions" on that page Item 7 7. How do I load envelopes?
Also includes details of how to set the print driver up
Printer Driver Settings
  • Media Type : Envelope
  • Page Size: Select either DL Env. or #10 Env. according to the envelope size you are using
  • Orientation: Landscape
Apr 10, 2010 | Canon Office Equipment & Supplies
How topaper load cannon mp 160 pixma
Loading Paper into your Canon MP 160 Pixma.
A) Loading Paper :
Follow this procedure:
1) Open the Paper Support, then pull out the Paper Support Extension.
2) Place a stack of paper (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Set the Paper ThicknessLever to the correct position for the paper.
Note : Set the Lever to the left for most paper. When the Lever is set to the right, the confirmation message appears before the machine starts printing.
Important : Make sure the stack does not exceed the Load Limit Mark.
B) Loading Envelopes
Follow the following steps:
2) Prepare the envelopes for loading.
Important : * Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
* Remove any curling by holding the edges diagonally and bending them gently.
* If the edges of the envelopes are inflated or curled, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
* Ensure that no curl or puff exceeds 1/8 in. (3mm).
3) Place the stack of envelopes (print side up) in the Auto Sheet Feeder, pinch the Paper Guide and adjust it to the left side of the stack.
* Load the envelopes in the Auto Sheet Feeder with the short side down.
* Set the Paper Thickness Lever to the right.
Important : Make sure that the stack does not exceed the Load Limit Mark.
Hope this helps. PLease rate my response.
Thanks
Have a good day.
Dec 01, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Diagram on how to plug an mx320 canon up to a computer
This is Canon Support, and the Getting Started guide which tells you, and shows you, how to properly cable up your Canon Pixma MX320,
http://gdlp01.c-wss.com/gds/0/0300001870/01/MX320_GS_EN-US_V1.pdf
(Copy and paste the above into your address bar, then press the Enter key)
Should this link not work for you, here is Canon Support, and the download page the link came from,
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18119
Scroll down to the - Guides and Manuals heading. Below this heading at the bottom of the box, there is - Getting Started
MX320_GS_EN_US_V1.pdf ,in red. Click on this.
You may not see anything happening for up to 20 seconds. I downloaded it just now for a test, (To make sure it's working), and I had to click MX320_EN_US down in my system tray, at the bottom of the monitor.
Pages 3, 4, and 16 tell, and show how to hook up the cabling.
Essentially you are attaching the phone line to be able to use Fax, attaching the power cord for power to the MX320, and attaching the
USB cable from the MX320 to the computer.
You MUST set the MX320 up first, and MUST install the software first, BEFORE attaching the USB cable.
(The USB cable plug end, that goes into the computer is Flat.
It is a USB A male plug.
The USB cable end that goes into the MX320 is Not flat.
It is a USB B male plug. Square shape with the top two corners cut off.
This USB B plug goes into the back of the MX320. In the middle of the back there is an inset, or indention. The plug goes in sideways.
Should you have attached the MX320 to the computer with the USB cable, BEFORE you installed the software from the Installation CD, let me know.
[1.Make SURE the MX320 does not have the USB cable plugged into it!
Turn the MX320 off, and unplug from power.
2.Go to Start>Control Panel>Add/Remove Programs, and Remove theCanon software. All of it. Anything you see listed with Canon relatingto the MX320.
3.If it asks you to restart your computer, do so. If it does not, do so anyway.
4.After Windows has fully loaded, insert the Canon MX320 Installation CD disk. Install the software. If it asks you to restart your computer do so, if not restart it anyway.
5.After Windows has fully loaded, plug the MX320 into power. Press the Power On button. Give the MX320 time to set itself up.
Now plug the USB cable into the MX320.
You should soon see, 'Found New Hardware', and also perhaps, 'Found MX320' ]
Nov 18, 2009 | Televison & Video
Can't print DL envelopes on a Pixma iP4600
Hi ...
If you like to print DL envolopes, check the below 3 points and I am sure you will be able to print from your printer.
Prepare the printer:
  1. Open the Rear Tray and pull out the Paper Support. Put your finger in the rounded indent of the Paper Support and pull it out until it stops. (See <1> in Figure 1 below.)
  2. Open the Paper Output Tray. Put your finger in the rounded indent beside the Paper Output Tray and open it gently. (See <2> in Figure 1 below.)
  3. Open the Output Tray Extension. Open up and set the Output Tray Extension completely by pressing down the hollow on its front side. (See <3> in Figure 1 below.)
  4. Adjust the position of the Paper Thickness Lever. Set it to the right when printing on envelopes or T-shirt transfers, and left when printing on any other type of paper. (See <4> in Figure 1 below.)
    * Figure 1
  5. Load the envelope.
    1. Load the envelope against the right side of the Rear Tray. (See <1> in Figure 3 below.)
    2. Load the envelope with the address side facing UP and the rear flaps DOWN on the left. (See Figure 2 below or, <b> in Figure 3 below.)
      * Figure 2
    3. Pinch the Paper Guide and slide it against the left side of the envelope. (See <2> in Figure 3 below.)
      * Figure 3
      Note: Reset the Paper Thickness Lever to the left when you finish printing. (See <3> in Figure 3 below.)
Preparing Envelopes to Load:
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
Paper Type
Precaution
Envelope*
DL / #10
Set paper with the flap closed.
Unsuitable Envelopes:
  • Envelopes with an embossed or treated surface
  • Envelopes with a double flap or pressure seals
Printer Driver Settings:
  1. Select Envelope in Media Type.
  2. Select the size for envelopes.
    * In Windows, select DL Env. or Comm. Env. #10 in Page Size.
    * In Macintosh, select DL Envelope or #10 Envelope in Paper Size.
  3. Select Landscape in Orientation.
Note:
  • Be sure to set the printer driver setting properly. If you do not, the address will be printed in the wrong direction.
  • It may be required to change the paper size option to 'Envelope' in File Page Setup menu.
Don't forget to vote if this helps ... Cheers :)
Jul 27, 2009 | Canon PIXMA MX310 All-In-One Printer
228 people viewed this question
jasbo
jasbo
