Question about Frigidaire GLEQ2152ES Electric Dryer
The dryer is not heating up. I have cleaned the lent tray and have tried the different settings (whites, colors med,) and none of them are heating up. Could this be the coil or the heating element?
  • Frigidaire Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
My estate dryer model #eed4400wqo
I suppose you want to clean the lint vent to outside. Clean out the filter first by removing the manual filter and pulling off all stuck lint. Try this link to clean the vent:
How to Clean Clothes Dryer Vent
Feb 12, 2015 | Estate Eed4400wq 29 6.5 cu. Ft. Electric...
What do the colors mean for the ion settings pink gray white
I have the RVHA6002c model and it does not have colors codes just selector with low med and high so maybe that is what the colors stand for. wish I was more helpful good luck
Jun 14, 2014 | #Mega Revlon RVHA6001 Titanium Ion Hot Air...
I have a Lennox Diplomat furnace. How can I tell if the blower motor is set for high speed when it comes on?
The only way to really tell if the blower is set to high is to look at the control board inside the furnace and see how it is hooked up. You will have either a 3 speed or 4 speed blower motor, more than likely a 4. These are Hi, Med Hi, Med Low, Low. Each speed has its own color and if the motor has ever been changed, it could be different from factory diagrams. The most common colors/speeds are:
Black- Hi
Blue- Med Hi
Orange- Med Low
Red- Low
You could have different colors but they will be close. If it's an aftermarket motor, the speeds will be listed on the motor itself, but very difficult to get to sometimes. On the board, you should have terminals marked, COOL, HEAT, PARK, PARK. You hook what speed you want for Cool and Heat and put the other 1 or 2 wires on Park.
Again, these might not be exact, but these are the basics and they usually don't deviate from them to much unless it's a 95% furnace or such. If you do have the diagram for the furnace, you will be able to find everything with no problem now that you have the basics. Also keep in mind that you will have a Common wire from the motor that hooks to Com. terminals on the board. Hope this helps and good look!
Jun 19, 2012 | Heating & Cooling
My maytag neptune dryer doesn't blow any hot air
on top of the heating element on the left side there is a white 2connector part, that is the heater thermal fuse. disconnect the dryer power cord and one wire of the thermal fuse and use a meter to find out if you have continuity to it. if not replace it. also check for burn wires at heating element. also test heating element by disconnecting one wire and using an ohm meter test it at 2 therminals. it shoul measure 10-12 ohms.
Feb 14, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The dryer has does not always heat. You can turn the temp knob to different settings and it will sometimes heat up. It may work on the hottest setting one time then on the med or low setting another...
heatman101
Dec 27, 2010 | Hotpoint Dryers
Lent is damp dryer takes too long to dry and burning smell
Your burning smell might just be lint which has been loosened by you, getting onto the dryer's heating element. If this is the case, the smell should not last long, nor will it damage the dryer.
Sep 10, 2009 | Dryers
We have a Kenmore 110 6092299 90 Series dryer. The motor still runs - but no hot air, at all. I've tried timed and heat dry. Nothing. It just tumbles and it takes 4-5 rounds to dry. At first we were told...
Sounds like the heating element or the thermo-cut off. A vent being clogged for some time, can cause too much heat to build up and make the element or cut off fail. These are the 2 most common things.
May 05, 2009 | Kenmore 63942 Dryer
I have to use my indesit condensing tumble dryer about 3 times to get 1 load to dry
Hi.
Make sure the fluff filter and water tray are clean and empty.
Also make sure it is on High heat setting, and set the correct time.
Nov 28, 2008 | Dryers
After a few loads the dryer shuts off before the time cycle is finished. The lent screen is clean and the lent exhaust is clear. My dryer is whirlpool mod. GEQ9858JQ8.
the motor is over heating cutting out on the thermal overload inside the motor replace the motor 279787 part number
Apr 17, 2008 | Dryers
Kenmore Heavy Duty 60 Series Soft Heat Large Capacity Dryer
i need to take the bottom lent door off. I have replaced the board and it still say's says to clean the lent door. i have with the one in the dryer, but need to clean the bootm .
Feb 23, 2008 | Kenmore 63942 Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
