Question about HP Pavilion a6000n (882780985018) PC Desktop
Hard drive was pulled from an Hp pavillion a6000y. When a hard drive from a different computer is installed, the blue power light comes on but nothing happens. CD drive is accessible, but monitor does not even recognize any signal.
3 Suggested Answers
  • 644 Answers
SOURCE: My HP Pavilion a6300f powers up but no signal to the monitor
It could be the motherboard, try resetting the the bios first by either taking the lithium cmos battery out and then replacing after 30 secs or finding the the cmos jumber and unshort it for 30 secs, and reboot the mechine.
If the same and no monitor responce then the onboard graphic electronics may have failed, the motherboard does have a AGP expansion slot which you may want to test with a graphics card to see if that will work.
If you find that you do have to replace the motherboard, try to find one that uses the same processor and memory that you already have, that way you will keep expence down to a minimal.
Replacing the motherboard will mean you will have to contact microsoft to give you the installation codes for the operating system to work with the new motherboard, when you boot for the first time with the new motherboard fitted you will have to phone the number on the screen to reregister the system just follow the instructions, it is quite self explanetry.
Once all booted up and drivers installed the computer should run as normal, as for the hp recovery disks it should still work as all the information on the disk is on the harddrive any way, the only thing you would need to do is keep the motherboard installation disk with all the drivers on.
hope this helps.
Posted on Mar 23, 2010
Testimonial: "Thank you for taking the time to reply and for your suggestions."
  • 33 Answers
SOURCE: No signal output.
go to the cmos setting and disable the sata native support in the system configuration
Posted on May 24, 2010
Hp pavillion p6313w will not work ...i have fans and power light but no screen
Hard to say without seeing the machine. Is there a hard drive activity light that is flashing? Are there any beeping noises? Have you tried a different monitor? Could be motherboard problem, but one hopes this is not the case.
Apr 15, 2013 | HP Pavilion p6313w -24058
I have an HP Pavillion dv9000 the blue lights come on for just a sec and then nothing. It will turn on periodically and works great when it on. But that is the problem it hardly ever does. Just the blue...
This could be lots of things. so lets try the easiest.
Blow out the dust in and around the fan(s)
replace the AC power cord and/or battery.
replace hard drive
and the big one replace Motherboard (which i done once in my lifetime)*
* = most likely not it.
Nov 02, 2010 | HP Pavilion dv9000z Notebook
Hello, I have owned my HP Pavillion for 3years and have not had a problem until yesterday when I started it up. The computer comes on but I can't get past the HP blue screen! Nothing happens at all and...
Of course - can you boot into SAFE-MODE? or LAST KNOWN GOOD CONFIGURATION? do this by pressing the F8 key repeatedly just after you power on the pc-- then choose LAST_KNOWN_GOOD
Apr 11, 2010 | HP Pavilion a6600f Desktop PC
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
Hp pavillion dv2210us harddrive failure
sounds like it may have died try it in an external mount (on a different computer)
Aug 13, 2009 | Dell Latitude D600 Notebook
My hp dv2000 will not start or boot
What happens when you just boot the computer without the hard drive installed?
Jun 15, 2009 | Computers & Internet
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
HP Pavilion zv6000 won't power up after getting zapped
It sounds like you have a piece of junk, the hard drive mighr be OK , if it is you can put it into a USB hard drive adapter case and use it as an external USB hard drive.
May 05, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
Laptop hp pavillion ze4300
Probably bad memory or loose CPU module. First try removing and resetting CPU. You'll need to remove Keyboard, Palmrest, and heatsink and shield beneath Keyboard. You'll need a small Phillips screwdriver to remove screws and small standard size screwdriver to loosen screw holding CPU. After removal/reset, put everything back together and try powering back on. If still same problem, replace memory located on bottom of LT located behind door. Also, you may have a memory module located under Keyboard next to CPU that may be bad.
Jan 06, 2008 | HP Pavilion ze4300 Notebook
HP Pavilion a6000n (882780985018) PC Desktop Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
