Question about Refrigerators
Huke air conditioner stops with e4 error - Refrigerators
likha
  • 790 Answers
SOURCE: E4 Error Message
ok sir! are you sure is the sensor are cleaned? your unit need to general cleaning specially the sensors!
Posted on Oct 16, 2007
  • 68 Answers
SOURCE: Error code of E4 on Dometic HP air conditioner ??
16. SYSTEM RESET
a. Turn the ON/OFF switch to “OFF” position.
b. Simultaneously depress and hold the MODE and ZONE
push-buttons while turning the ON/OFF switch to “ON”.
FF should appear in the LCD display until the MODE
and ZONE push-buttons are released.
c. When a dip switch is turned on or off after initial configu
ration, a system reset will need to be done before the
Comfort Control CenterTM will recognize the updated selection. Try this. This is for the five button thermostat. Did you check the dip switches to be sure the proper ones are turned on? I need to know which stat you have 4 or 5 button. I have trouble shooting for both.
If you notice reset needs to take place after a dip switch is turned on or off. The dip switches are on the circuit board. You need to drop the lower cover. the dip switches will read in this order #1 heat strip/ #2 zone2/#3zone3/ #4 zone4/#5 furnace/#6 differential/#7stag/#8 gen start. Check this out and be careful. Turn off the stat to change dip switches. On will be toward the description. If you don't have remote start gen set the dip should not be on. If you dont have a Zone 3 the dip should not be on, etc.
Any questions feel free to post back
Thank you for using fixya
Jerry
Posted on Mar 26, 2009
SOURCE: E4 error message on Dimplex portable air
Ensure water emptied
Posted on Nov 02, 2009
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
hvac1960
  • 2133 Answers
SOURCE: E4 error on Yamatsu S-24H
E4Fault indoor coil sensor (open or closed). Replace it.
Posted on Dec 14, 2010
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Unit stopped, displayed E4
the unit is not draining properly. unplug it from the current outlet, check behind there should be two places to drain the machine. unplug the two drain plugs in the back and let the water empty out. the e4 error message comes up when the unit is filling up with water.
Sep 04, 2011 | Royal Sovereign Portable Air Conditioner
I have a Huke wall mounted aircondotioner after you turn it on it cools for about 10mins switches off and shows a EL error message
Check the compressor and see if it is working. If it is working then change the capacitor. This should help with the error code EL. The huke aircon should work properly unless the gas is low.
Mar 20, 2011 | Heating & Cooling
E4 error on Yamatsu S-24H air conditioner ?
Dec 14, 2010 | DeLonghi PAC85 Portable Air Conditioner
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
Jul 12, 2009 | GE APH10AA Air Conditioner
E4 Error
york hvac unit e4 error code Troubleshooting
Aug 05, 2008 | DeLonghi CF210 Portable Air Conditioner
De Longhi E4 error
Basuda! Sorry! Cheaper to get another one than to fix!
Nov 06, 2007 | DeLonghi CF210 Portable Air Conditioner
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
