Question about RIM BlackBerry Bold 9000 Smartphone
My problem is ringer volume i cant when someone is calling
  • 358 Answers
Hi, when a phone has a ringer volume problem, is either the ringer of the phone is weak and you can't hear when someone calls you or the volume of the ringer is yet at a very low level in sound.
You will need to check the volume settings of the phone if the volume is low so you can increase it to a high level.
If the setting of the volume is high, that means the ringer that a makes you hear when people call is weak and will need to be replaced.
Any further question or comment, you can pass it on as comment.
Take care.
Posted on Oct 14, 2010
How do i download a free alcatel ringtone for incoming calls
Do you have the ringer volume turned all the way down which is to say you hear no ring, check that first, if the ringer volume is turned up then the phone is defective and needs to be repaired or replaced depending on cost.
Mar 16, 2017 | Alcatel Cell Phones
How to make a Nortel phone model M7310 ring
If the phone doesn't ring when called by the extension number of the phone then try to use the volume up button while someone is calling the phone. The volume is a multi-purpose button that doubles for phone volume and ringer volume. However, the only way to turn up the ringer is when a call is coming into the phone.
Feb 18, 2015 | Nortel Lands Phones
Can not turn up the volume when answering or calling someone
while on the phone press the side volume buttons up or go to call settings
Apr 20, 2013 | tracfone.com
My setting for ringer is turned on, but my phone doesn't ring when someone calls me???
It could be that your selected ringtone is inaudible. Go into your settings and test the selected ringtone for calls. If you can't hear it, try another. Also check your ringer volume setting. It may be all the way down.
Nov 16, 2012 | Apple iPhone4 4G iPhone 4
Whenever someone calls my nokia e52 just blinks but it does not ring. Is this comon problem of this tipe
Only if you have the ringer turned down or off ... set the ringer volume. If this doesnt work ... call your service provider.
Nov 04, 2010 | Nokia E52 Smartphone
I cant turn up the volume on the second cordless phone. how is this done/
Do you want to turn up the ringer volume or the call volume?
To adjust the volume of the ringer press the UP or DOWN arrow on the pad to bring up the main menu. Move to the 'Handset setup' icon and press OK. Select 'Ringer Setup' and press OK. Now select 'Ringer Volume' and OK. (At this point if you have 2 incoming lines you will need to select the correct line). The display will now show the volume, use the UP and DOWN arrows to adjust the volume. When finished press the OK button, then press the CALL END button to return to the main screen.
Adjusting the call volume is easier. When you are on a call use the UP and DOWN arrows to alter the volume.
I hope this helps.
Jul 19, 2010 | Panasonic (KX-TG1032S) Phone
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
2 Scroll to “Ringer setting” by
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
Turn ringer on T7316
T7316 Manual
The volume control adjusts the handset, hands free, headset, and ringer volume. Someone may have fiddled with the buttons and turned the ringer down enough that it doesn't sound when a call is incoming.
Feb 12, 2009 | NorStar Meridian M7310 Phone
RIM BlackBerry Bold 9000 Smartphone Logo
574 people viewed this question
Top RIM Cell Phones Experts
Longtime User
ismael castillo
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
