Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
When turning tv on it goes in to standby and doesn't come on . I used to be able to unplug it and wait awhile plug it back in and it will come on
    Genius:
  • 1,126 Answers
If you have some garbage in the main processor you need to leave it unplug for 40 MIN, to reset it back to normal. If that don't work then you need to check for a shorted horizontal transistor, mounted on a metal heat sink near the fly back transformer, that is what turns your high voltage on.. If that is good , then the next common problem would be is a bad convergence module, and you are looking at around 400 on repairs.
Posted on Oct 14, 2010
  • Anonymous Oct 14, 2010
  • 998 Answers
One of the convergence ic is defective or shorted try to check or compare the reading to the other convergence to be sure.
Standby light flashes and TV won't turn on. Have to unplug it and wait for a bit then plug it back in and TV turns on. Quite a delay though. Then after TV is turned off, standby light starts...
seems like a power supply problem inside the tv and when the transformer gets warm it is giving you problems you might have to get a tech seviceman to come out and have a look at it as it is not a job you should do yourself when it comes to replacing the power supply hope all goes well
Jul 06, 2011 | Samsung LN52B530 LCD TV
I replaced the lamp bulbs and the TV worked fine for awhile but shut off after about three days of use. I unplugged it and waited awhile to plug it back in the timer light blinked for awhile and then went...
While it is suspicious happening so soon after lamp replacement, your main power supply may have failed. In earlier sets, these were problems that eventually happened.
Feb 15, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
WHEN I TURN ON THE POWER THE THE RED LITE COMES ON
We have a TV that does this after we have left it off but plugged in for awhile when we go on a trip. Just unplug the TV, wait a few seconds and plug it back in. If it's like ours, you'll find that resets it.
Nov 19, 2009 | Loewe ARC332 32" TV
When you turn on tv it try's to come on then it goes off with standby light on red If you turn it back on it try's for a second then goes off again - you then have to unplug wait a few seconds plug back in...
the power board is fried and needs professional intervention Usually when these drop out there are other factors involved in the sound and picture boards as well;.There is no magic fix!
Please rate our help++++Thanks for using FIXYA
Oct 05, 2009 | Televison & Video
My Polytron TV is on standby mode. I used the remote but wont turned off
When you turn that TV "off" with the remote it go's into standby mode, that is the way they made it unfortunatly
To actualy make it not have any power going to it you will have to unplug it or plug it into a power strip and use the switch on the power strip.
They use the standby mode to allow the TV to turn on quickly without making you wait.
Jul 19, 2009 | Panasonic Televison & Video
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Red led stays on after turning off.
Aren't you talking about the standby led? cause that is perfectly normal... when it's on it means you can turn the TV on by remote, usualy it goes away when you turn the TV off manualy by pressing the OFF button on the set, but is this really your problem?
Jun 23, 2006 | Hitachi 53FDX20B 53" Rear Projection...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
