Question about Eliminator MotoMaster Mobile Power Inverter 700w
My MotoMaster Eliminator 400W inverter is making a clicking noise while recharging. Is this normal?
3 Suggested Answers
  • 323 Answers
SOURCE: Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Posted on Nov 06, 2009
SOURCE: who makes MotoMaster power inverters? I cannot
Hello D,
The Canadian Tire is selling the MotoMaster power inverters.
Please visit the link provided below :
After opening the link search for MotoMaster power inverters in search box and you will find the solution
http://www.canadiantire.ca
Posted on Oct 13, 2011
Why doesn't it charge?
Carolyn, These power boxes were not made to last, the batteries inside are probably bad now, if still under any warranty return for exchange or hopefully refund.
Feb 09, 2016 | Eliminator MotoMaster Mobile Power...
What does ocp mean on the 3000 motomaster power inverter
Unit is overheating.
1. Check fans are running. and unit is in a cool place where air can flow freely.
2. If fans not working try using an external fan to see if the OCP error goes way.
Reduce the load on the outlets (Disconnect some stuff i possible)
Apr 04, 2014 | Eliminator MotoMaster Mobile Power...
Motomaster eliminator 2 in 1 spotlight/lantern power
I am looking for a charging cord...I moved and haven't seen it in a while. Is there somewhere i could buy one.
Dec 02, 2013 | Eliminator MotoMaster Mobile Power...
My motormaster eliminator mobile power pack 700A just started beeping. What is wrong with it?
if there is a car fuse, under the cover, remove it.
most of the time, it is only use to activate the LOW Battery alarm.
Put the fuse back, when fully charge.
Jul 10, 2011 | Eliminator MotoMaster Mobile Power...
Have an eliminator intelligent battery charger model CT-1200A 11-1513-8. Can this be used to keep a car battery charged for a period of say 3 months while car is not being used. I have this same question...
· Automatically switches from full charge to maintenance mode to maintain batteries during prolonged periods of storage without overcharging or damaging the battery
Nov 27, 2010 | Eliminator MotoMaster Mobile Power...
Motomaster has two pos and neg connections for batteries cables do i need to hook up both before i can use it
I have the Motomaster 1750W. It just beeps if I try to turn it on with only one set of wires connected. When I run a pair of +/- cables from each of the connections, even to the same battery, it works find.
Oct 24, 2010 | Eliminator MotoMaster Mobile Power...
Can i run a camper off a power inverter
A 12 volt camper can be run off an inverter if the inverter has the capacity. The camper must be 12 volt right, just bulbs and such?
Jun 18, 2010 | Eliminator MotoMaster Mobile Power...
I have 1750w mobile power inverter turn on light comes on then the falt light come on right away.
Like most Cheap square wave inverters, the mosfets can not take the inrush current.
Usually if the fault light comes on and there is NO voltage at the output, FIRST check the on board fuse, then check for any tell-tale burn spots, or areas where the components have heated up or burned.....if you get this far and all appears clear, then it is time to check the fets.
I would not reccomend any Motomaster Eliminator inverter other than the more costly sine wave unit....or stay with a 1kw unit and do not overload it.
It\s best to run as much as you can at 12vdc or higher...like 24vds. AC is nothing but problems.
Apr 10, 2010 | Eliminator MotoMaster Mobile Power...
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
Eliminator MotoMaster Mobile Power Inverter 700w Logo
546 people viewed this question
Top Eliminator Electronics - Others Experts
ottworld5982
Pierre Curtis
Level 1 Expert
Tom Chichester
Are you an Eliminator Electronics - Other Expert? Answer questions, earn points and help others
