Question about Hand Tools
Was given an advance timing light made by craftsman .what is operating procedure?
  • Hand Tools Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly.
Here is the user's manual:
http://www.reinsmith.net/content/automotive/Craftsman_Inductive_Timing_Light_Models_21027_%2021023_Owners_Manual.pdf
You connect the Red alligator clip to the 12V DC positive battery cable and the Black alligator clip to the negative battery terminal OR chassis ground. The inductive lead always is clipped on the the #1 cylinder spark plug wire and then you shoot the light on the area of the engine where the timing marks are. Timing marks are not in the same place on each engine. Older V8 engines the timing mark is on the harmonic balancer on the front of the engine. Newer small engine vehicles such as Honda the timing marks are on the flywheel and you will have to remove a rubber plug from the bell housing to see the marks. Also some manufacturers have you check timing with the vacuum advance hose removed and blocked from the distributor. Most timing information is in the engine data specifications of the vehicle owners manual.
Thanks for choosing FixYa,
Kelly
Posted on Oct 14, 2010
I have lost my smart remote key for my Mazda CX-9 2011. Can I program a new one myself?
You may need 2 keys to do this, possibly just one. My source does not specify if 1 key will work but here is the procedure i found
With two programmed advanced keys
  1. Bring the programmed advanced keys (2) and a unprogrammed advanced key into the vehicle.
  2. Close all doors.
  3. Insert the supplementary key into the ignition key cylinder. NOTE:
  • Complete the procedures up to Step 7 within 30 s after the supplementary key is inserted.
  1. Turn the ignition switch to the ON position.
  2. Press the UNLOCK button on advanced key 1.
  3. Press the UNLOCK button on advanced key 2.
  4. From the ignition switch in the ON position, switch the ignition switch in the order indicated below.
  • ACC->ON->ACC->ON->ACC->ON
  1. Open the driver-side front door, press the door switch twice , and then close the door. NOTE:
  • After Step 3 is completed and the advanced key programming mode is activated, the door lock actuator operates to lock, and then operates to unlock.
  • If the door lock actuator does not operate, repeat the procedure from Step 2.
  1. Press the UNLOCK button on the unprogrammed advanced key twice . NOTE:
  • After Step 8 is completed and the advanced key is programmed, the door lock actuator operates to lock, and then operates to unlock.
  1. If programming more advanced keys, remove the supplementary key once, and then repeat the procedure from Step 2.
Aug 04, 2016 | 2011 Mazda CX-9
Hat remote will work with sears craftsman poweriii model 139.53403
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 11, 2014 | Televison & Video
Tv not working
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Counting procedure to Philips TV LED blinks are not direct. It is different to that of other brand TVs. Details about it is given by the site.
Apr 07, 2014 | Philips 32PFL7403D 32 in. LCD TV
HOW DO I TIME A 1000 XLH
This is a difficult operation without the proper tools. I just did this on my 1981 XLH1000 because I replaced the Cam Set. Things you really need are the clear timing plug for the timing access hole, and a timing light with an advance control adjustment for the strobe.
http://www.sears.com/craftsman-advanced-timing-light/p-00914065000P?sid=IDx01192011x000001&kpid=00914065000&kispla=00914065000P
Sears makes one and I bought it many years ago. It makes timing so easy, that I would not attempt timing without it. REALLY. It turns a long tedious job into a 10 minute job. The rotational adjustment of the ignition base plate on the opposite side of the engine is a coarse adjust at best, and it is very easy to miss the timing mark in the window. With the adjustment on the timing light, you can twist the knob and see exactly how many degrees you are off. I never make adjustments while the engine is running, only measurement of where the mark is with relationship to the clear plug. Do not screw the plug in all the way, otherwise it will contact the flywheel and scratch it badly, rendering it useless.
It's really important to set the idle at 2000 or above, to make sure the engine is fully advanced.
To get the engine to start when you first start trying to time the ignition, follow the procedure below.
This should be enough information for just about anyone to set timing on a XLH Sportster
Good Luck!
Turbocouch
Aug 19, 2013 | Harley Davidson XLH 1000 Sportster...
2003 Ford Expedition XLT 4X4 4.6L. 70,000 miles. Had a rough idle then stalled. Happened 4 times today. CEL reports a lean left bank. Just finished changing spark plugs and fuel filter. Plugs were fine....
Cam Phasers. There is an Extended Warranty for them. What happens is the Cam Phaser is suppose to automatically adjust each cylinder bank independently. When one of the Cam Phasers gums up, it can leave a Cam over-advanced.
An over-advanced Cam will be lean and generate a lean Code for that side of the engine. An engine with one bank operating at 1 timing setting and the 2nd bank operating at a different setting will run rough and stall before blowing up.
Ford has given a 7 Year, Limited mile Extended Warranty for those DOHC engines having this problem. This can be a costly repair of around $2400. A recently developed "Cheater Procedure" can cut Labor from 8 to 4 hours with savings in gaskets resulting in a $1200 to $1600 repair.
Your vehicle may develop a Diesel sound which fades at 2000RPM. So contact a Dealer with a VIN# and go from there.
Jun 19, 2011 | Ford Expedition Cars & Trucks
I have bought a replacement tranmitter for 2001 Suzuki Ignis Remote Central Locking System. I have an original that works but cannot Program the new one as per Owner's Manual given to me when the car was...
TRY THIS IF DONT WORK DEALERSHIP HAS TO REPROGRAM TRANSMITTER.REMOVE KEY FROM THE IGNITION SWITCH.CLOSE ALL DOORS.SWITCH IGNITION ON.WITH IN 10 SECONDS, SWITCH IGNITION OFF AND REMOVE KEY.WITHIN 20 SECONDS, PRESS AND RELEASE DRIVERS DOOR COURTESY LIGHT SWITCH 3 TIMES, SWITCH IGNITION ON, WITHIN 10 SECONDS ,SWITCH IGNITION OFFAND REMOVE KEY.LOCKS WILL CYCLE TO CONFIRM PROGRAMMING MODE ACTIVATED. PRESS THE UNLOCK DOOR BUTTON TO CONFIRM THE DOORS OPERATE FROM LOCK TO UNLOCK. REPEAT PROCEDURE REMAINING REMOTE TRANSMITTER.IF THIS DONT WORK DEALERSHIP WILL HAVE TO REPROGRAM NEW REMOTE.
Apr 18, 2011 | 2001 Suzuki Swift
My night hawlk go 0 to 60 no problem when I get on the way I cam go 65 it bogs out even if I try to choke it to save it got new crabs,oil,plugs,airfilter???
Sounds like no timing advance. Will seem to go well up to about 55 or 60, but will run flat or even slow down above 60. Follow shop manual procedures for verifying timing advance operation. If you watch the timing mark with a conventional timing light, you will most likely discover the mark will not move when you rev the throttle. If this is the case, you must replace the electronic timing pickup or module. Consult shop manual for the correct procedure.
Apr 08, 2011 | 1986 Honda CB 700 SC Nighthawk
Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sanyo plc se15 no light output
i all,hoping you can help with my problem.Ihave been given a sanyo plc se15 projectoe but with no lamp originally,the "lamp"indicator and "lamp replace indicator"were originally lit but when i have installed a new(23hrs use previously) lamp i have no light output and these 2 indicators are still lit! what voltage should i have on the lamp terminals(i a fully qualified electrician btw) is there some sort of reset procedure as i dont have any instructions etc
thanks in advance for any help
Mar 05, 2008 | Sanyo PLC-SW30 Multimedia Projector
Canon pixma mp150
Mp150
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Feb 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Hand Tools Logo
221 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
