How get to safe mode on a compaque computer - Computers & Internet
How do I get out of safe mode on my dell vastro 2521?
Once you have solved the problem that sets it in "safe mode", you can reboot the computer into normal mode.
Look in the Control Panel.
Pick device manager and look for a yellow balloon, which will show why it is still in safe mode.
Mar 06, 2015 | Dell Inspiron Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Remove my pc virus
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials
Hope this helps.
Dec 30, 2012 | AVG Anti-Virus & Firewall 9.0 (2...
Remove virus of my computer
Enable VGA mode
Reboot
Dec 13, 2012 | Computers & Internet
WHERE DO I FIND SAFE MODE IN LAPTOP OF HP 6735s
Enter Safe Mode at startup Follow the steps below to start Windows Vista in Safe Mode.
  1. Remove all CDs and DVDs from the computer.
  2. Restart the computer.
  3. At the first screen on restart, before the HP or Windows logo appears, press the f8 key repeatedly.
  4. When prompted, select the Safe Mode with Networking option.
  5. Log onto the computer with a user account that has administrator rights.
Enter Safe Mode when PC is operating If the computer can boot into the Vista operating system, follow the steps below to enter Safe Mode.
  1. Click Start , type msconfig in the search field, and then press the enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Diagnostic startup .
  3. On the Boot tab, select Safe boot and click OK .
  4. When prompted, click Restart to start the computer in Safe Mode. If the computer does not restart automatically, press the Power button to turn the power on.
  5. On the Tools tab of the System Configuration window, select and launch the desired diagnostic tool.
The computer is now operating in Safe Mode. Exit the Safe Mode After completing the required troubleshooting and repair, follow the steps below to exit Safe Mode and return to normal operation.
  1. Click Start , type msconfig in the search field, and then press enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Normal startup and click OK .
The computer restarts in the normal mode.
May 18, 2012 | HP Compaq 6735s Notebook
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
How run in safe mode with windows vista
When you turn on your computer, press F8 and that will give you some start up options, the first ones being Safe Mode, Safe Mode with Command Prompt and Safe Mode with Network.
Nov 01, 2010 | Computers & Internet
Please explain step by step how to reboot a computer into a safe mode?
to boot a system in safe mode restrt your computer as the computer starts press F8 you will see a set of command like safe node safemode command etc click safe mode you will see set of files running wait till the safe mode starts the you will be able to see the mouse icon then it will ask do you want the computer to start in safe mode click yes now you are in the safe mode section in safe mode section the system starts in defult setting you wont be able function somefunctions safe mode is for correctiong your computer or to remove unwanted software or hardware
Oct 26, 2010 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Can't get computer out of safe mode
From Windows Safe Mode click Start / Shutdown and restart the computer. This should start the computer automatically back into Normal Mode.
Note: Many users believe that they are still in Safe Mode because the colors or video may not look correct. Unless in the corners of the screen it says "Safe Mode", you are not in Safe Mode.
If you are rebooting the computer and it is rebooting back into Safe Mode (it does say "Safe Mode" in each of the corners), it is likely another problem exists with Windows preventing it from loading into Normal Windows.
If this does not work try: http://www.computerhope.com/basic.htm
Dec 30, 2009 | Compaq Presario Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
