Question about Canon PowerShot SX100 IS Digital Camera
I have installed the disk with eos utitlity, etc. when i connect the camera and the window opens it says "failed to initialze". what can i do about this??? i have never been able to correctly use the camera and it is very frustrating.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Sep 30, 2012
marinos
  • 114 Answers
SOURCE: EOS Utility does not Recoganize Camera
I am not sure about this matter but it seems there is a problem with your new computer. it might not recognize the usb cable.
try to plug your camera in another USB port and try again.
Posted on Aug 20, 2008
  • 62 Answers
SOURCE: EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
Posted on Aug 28, 2008
SOURCE: My XT will not connect to Vista.
I had same problem. I tried the Canon customer support and got similar advice Muhammed gave, along with several additional steps to try. None of them worked. The only thing that worked was the above suggestion of setting the camera itself to the PTP for the communication setting of the menu.
It's too bad you have do do this work around, it does not allow for the same level of control as the pc communication setting.
Posted on Oct 20, 2008
  • 270 Answers
SOURCE: Canon EOS 1000D will not connect even with solution disc instaled
To find out if the computer recognizes the camera, go to start>computer and see if the camera is listed. If it is, you can double click the icon to open it. Double click on the folder(s) until you get to the pictures. Click on the first picture, scroll down to the last picture and while holding down the shift key click on the last picture. Now right click on the pictures and you will get a menu. In Vista you can select copy or move them to a folder. In XP you will have to select send to>documents then move them to a folder. As for the program you installed, if it didn't leave a short on your desktop, go to start>all programs and look for it. If it's not there, it probably didn't install correctly.
Posted on Jan 21, 2010
  • 11967 Answers
SOURCE: there is no install disk for the camera
Do what the pros do...use a card reader to download your pics.
Can't see picture of computer but can on camera
Install the Canon Raw software on the disk that came with the camera :-)
Jul 08, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
Xti download to pc
try doing a system restore to yesterday and then try installing the disk again.
You can do the restore from control panel and inside "Performance and Maintenance"
Please let me know it this still doesn't work and we can go from there in finding a way.
thanks
May 10, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Can't dowload picture to computer from Canon EOS 550D
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Apr 18, 2012 | Canon EOS 550D Rebel T2i Digital Camera
I can't boot up. it display error 2100: Hard disk drive initialzation error.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly.
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive
- CD drive
- Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Let us know how it works out.
Jan 11, 2011 | Lenovo T410 Notebook
Can not get the camera to intialize, it say initialzation error
Try uninstalling the USB devices in the Device Manager. Removing all of them will not hurt your computer. Unplug all of your USB devices and restart. The computer will load fresh drivers for usb. It would be a good idea to uninstall the camera software as well before doing this, and re-installing it after your computer has fresh USB drivers. If that does not work, take it back.
Jun 30, 2009 | Microsoft Life Cam Vx-5000 Webcam
My camera will not transfer pictures to my computer
Hi:
Please uninstall the previous software and drivers related to your Canon camera FIRST.
Now about try these steps in sequence.
1- Go to this link and down the drivers for you camera.
http://download.cnet.com/Canon-EOS-Digital-Rebel-EOS-300D-Digital/3000-18489_4-46246.html
2- Install the downloaded software. make sure drivers are installed.
3- Connect your camera to your PC, turn the dail to play and turn it on. It will install the drivers. When it is ready, you are able to download copy, Etc.
GOOD LUCK!!!!!!!!
Jun 19, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
40D not communicating with EOS utility
open device manager, connect camera, it will be seen briefly with yellow triangle and exclamation mark. open it up and uninstall.
Disconnect camera and close windows down. Restart windows, connect camera and switch on, windows will then find it and install driver. Took me hours to figure this one out
Mar 11, 2009 | Canon EOS 40D Digital Camera
Switched to MAC - have EOS40D and SX100 - will not download SX100
Yes, you need to install the SX100 driver software as well. I wouldn't overwrite older versions of the Canon software, though, so do a selective install if you can.
Feb 21, 2009 | Canon PowerShot SX100 IS Digital Camera
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Dec 27, 2007 | Canon PowerShot A560 Digital Camera
Canon PowerShot SX100 IS Digital Camera Logo
15 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
