Question about ASUS P5RD1-VM Motherboard
For booting the systeam
My sys fan are working smps is also work but the moniter does not show any tyme of singnle and on beep sound is come bcoz my sys is not on work last 5 mounth tell me solution
  • 3 more comments
  • idealyash Jun 02, 2008
    plz tell me
  • Anonymous Jun 10, 2008
    my asus p5rd1-vm problem, when start up only fan is on, no beep and no other activity, procesor ok when attached to other mobo...plse help me...
  • Anonymous Jun 14, 2008
    my sys fan are working smps is also work
    but the moniter does not show any type of singnle and on beep sound is
    come bcoz my sys is not on work last 1 week tell me solution, i had
    checked all the things changed the ram , powersupply but its not
    working for my PC, power comes in mother board , Cpu fan also starts,
    but on monitor it shows no signal, power comes in Mother board
  • Anonymous Jun 17, 2008
    the same problem, systme fun works, LED is ON, ni signal on VGA monitor.
  • weeest Oct 07, 2008
    same here :(
THE SAAAAMMMMMEEEEE problem with my asus p5rd1-V , when start up only fan is on, no beep and no other activity, procesor ok when attached to other mobo...plse help me...
Posted on Jun 20, 2008
"I tried to install another internal HDD + another 256 RAM (both of them are used) to my computer, operating XP with an ASUS P5P800S motherboard. When I ran the system, the new device was found by the sys....
The hard drive would not show up until you initialize it in the control panel. With everything off the motherboard you should get some post beep. Put the ram back and try again, the next thing to install is the video to see if there is any indication of function. Keep adding things back. If there is no post beep with just the motherboard then you need to test the PSU and if it is OK then CPU or motherboard is bad.
Sep 26, 2014 | ASUS P5p800s Motherboard Intel 848p Lga...
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Sep 09, 2011 | E-Machines eMachines Desktop PC
No my pc desnot boot no video but fans running no sounds not beeps
First remove the cover and remove all the power connectors from the smps the hold the 24 pin poerconector and short the green and black wire and see wether the smps fan is working if working remove the memory from the memory slot and clean the surface and insert it into socket and see wether the couputer boots
Sep 02, 2011 | Computers & Internet
Hpcompaq dx2200 tower pc my pblm is 1)cpu shows
old compaqs. came with XP windows, the dead OS.
what is shitch? ah, switch it one ...
smps? (SMTP?)\
count the beeps, its a code the code i bet is overheated.
The service Free, manual covers that.
the fan must work or the CPU overheats, fix fan first.
in fact all fans seen, there , inside and in PSU .
The CPU is smart, it slows down when hot and if the fan is dead
the CPU stalls. see? by design (intel inside did that magic) to protect itself.
HP supports it
https://support.hp.com/us-en/product/HP-Compaq-dx2200-Desktop-PC/1844701/model/1844702
ever clean it first?
http://www.pcdied.com/overheated.html
Aug 11, 2017 | Compaq (252608-001) Motherboard
No VIDEO!!
Dear,
pl check step by step.
first to hang up all hardware ram,smps,processor with heatsink fan,keyboard all.
After check any beep sound comes from motherboard.
remove ram and check beep sound
remove cmos cell,ide cable and check beep
sound.
NO COMES ANY TYPES OF BEEP SOUND PROBLEM IN *********** BOARD ALOSO CHECK YOUR RAM AND SMPS AT ANOTHER COMPUTER WORKING OR NOT.
Regards,
Ravindra shah
Jun 02, 2009 | Gateway (4000782) Motherboard
PC won't wake up.
make power on,
see the SMPS fan from back side in CPU, if its not working, mean you have problem in SMPS or in power supply cable. Try another power supply, also make sure that socket on wall is right and the current is available there.
If your SMPS is working then try to hear beep from CPU after booting, there must be a ok beep, if no beep, then it means there might be problem in your CPU.
Thanks
Iqbal
Jun 19, 2008 | Gateway Computers & Internet
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
ASUS P5RD1-VM Motherboard Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
