Question about HP PSC 750 All-In-One InkJet Printer
Type of usb cable - HP PSC 750 All-In-One InkJet Printer
    President:
  • 2,777 Answers
Sure thing, I have found the exact cable you need here. I have the link at the bottom of my answer...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
This is the cable, only $3.99:
http://www.amazon.com/gp/product/B001MXLD4G?ie=UTF8&tag=dependascient-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=B001MXLD4G
Posted on Oct 14, 2010
Lost cord
Hello
It depend on from USB to what type of connection that you camera support. Some of the cords you can find at local electronic or Phone shop store.
Apr 10, 2014 | eVision ClearView Digital Camera
Error code = 6A00 whats the problem
ou should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. (Refer to the illustration below to confirm the USB cable is in the proper orientation.) It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists. Note: Some printers have a type-A USB receptacle on the front to connect directly to a digital camera. The type-B receptacle, on the printer, will connect to the type-A receptacle on the computer with an A to B USB cable.
  1. Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, connect the USB cable directly into the computer.
  2. Repeat step one to reseat the cable on the other end.
    There shouldn't be any resistance when connecting the USB cable to the device. If the cable does not easily slide into the device's port, look at the end of the connector. The shape of the connector should match the port on the device.
    Note: All USB cables will have a USB icon on one side. The side of the cable where the icon is situated is different than the other three sides.
Icon on USB Cable
Shape of the USB Connector
  1. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  2. Make sure the correct USB cable type is being used.
Incorrect (A to A) USB Cable
Correct (A to B) USB Cable
Jan 04, 2011 | Canon PIXMA iX7000 Inkjet Business Photo...
How do you connect to your computer
You can buy this cable or use the one provided by Brother
Belkin PRO USB 6' Cable USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft
Belkin Cable 4 pin USB type A (M) , 4 Pin USB type B (M)
Detail in this link
http://www.superwarehouse.com/Brother_MFC-3220C_5-in-1_Color_Multi-Function_Center/MFC3220C/p/332703
Apr 22, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
What type of usb cord is needed for this printer
Hello there:
here is the information that you requested ok
I hope that this is very helpful for you
Best regards Michael
Cables for the Brother MFC-3220C 5-in-1 Color Multi-Function Center: corner1.gif Part# Price Status Qty. Belkin PRO USB 6' Cable
USB cable, 4 pin USB Type A (M) - 4 pin USB Type B (M), 6 ft F3U133-06 $8.99 In Stock Belkin 10' USB Cable
A/B Type, Hi-Speed USB 2.0, 10 ft F3U133-10 $14.99 In Stock Top
Nov 24, 2009 | Brother MFC 3220C All-In-One InkJet...
I lost mi cable
http://www.grabcart.com/product/comp/harddrives/cbbstore7292/USB-Cable-Dual-Power-2-x-Type-A-to-mini-B-USB-2-0-1m
USB Cable Dual Power 2 x Type A to mini B USB 2.0
Jul 26, 2009 | Maxtor OneTouch III Mini Edition 120GB...
MANUAL FOR KEYBORD 5188
Type 5C Keyboard to USB Adapter
Operation Manual
Type 5C Keyboard to USB Adapter 5188
TYPE 5C KEYBOARD TO USB ADAPTER Page 1
This equipment generates, uses, and can radiate radio frequency energy and if not installed and used in accordance
with the instruction manual, may cause interference to radio communications. It has been tested and found to
comply with the limits for a Class A computing device in accordance with the specifications in Subpart J of Part 15
of FCC rules, which are designed to provide reasonable protection against such interference when the equipment is
operated in a commercial environment. Operation of this equipment in a residential area is likely to cause
interference, in which case the user at his own expense will be required to take whatever measures may be required
to correct the interference.
Contents
Chapter Page
1. Specifications 2
2. Introduction 3
3. Installation 3
4. Technical notes 3
5. Part Numbers and Accessories 4
1. Specifications Compatible with:
Sunä Type 5C keyboard and mouse (includes Sun Type 6 keyboard)
Ultra Spec Server Control Switch, P/N 5185 or 5195
Sun Sunblade 100 workstation
USB compliant PC workstations (a USB compliant operating system which supports the USB HID 1.1
device class specification is required)
Power:
USB bus powered device. Current load is 100 mA max (adapter only). If also powering Type 5C keyboard
and mouse requires an additional 400mA max.
Size:
4.0” x 2.4” x 1.0”
Shipping Weight:
1 lbs.
Warranty:
Ultra Spec Cables, Inc. warrants all hardware and components of the Type 5C Keyboard to USB Adapter,
with proper installation and normal use, for one year from the date of purchase.
During the warranty period, Ultra Spec Cables, Inc. will, at its option, either repair or replace hardware and
components that prove to be defective.
If your product should fail during the warranty period, phone our technical support department at 1-800-
622-2537 for warranty service (return to factory) instructions.
TYPE 5C KEYBOARD TO USB ADAPTER Page 2
2. Introduction
The Type 5C Keyboard to USB Adapter (P/N 5188) allows a USB compatible workstation to be connected to the
Server Control Switch (P/N 5185 or 5195). The adapter converts keyboard scan codes from the type 5C keyboard to
equivalent USB keyboard scan codes. The adapter also converts the mouse data to USB compatible mouse data.
The Type 5C Keyboard to USB Adapter can also be used in a standalone setup, where it is connected between a
Type 5C Keyboard/mouse and a USB based workstation.
3. Installation
3.1 Between Type 5C keyboard and workstation (standalone operation)
For all installations it is recommended that the equipment be powered off for system interconnection and/or changes
to a setup.
• Connect the port labeled To Type 5C Keyboard to either minidin8 connector on the Type 5C keyboard using a
straight through minidin8 cable (P/N 8002 or equivalent). If using a mouse, connect it to the other minidin8
connector on the keyboard.
• Connect the port labeled To Computer USB Port to any workstation USB port using a USB Type A to Type B
cable (P/N 4021 or equivalent). This type of cable is used for connecting a HUB or other device upstream to
another HUB or a host controller.
3.2 Between Server Control Switch and workstation (system operation)
to a setup.
• Connect the port labeled To Type 5C Keyboard to any Server Control switch CPU port using a straight through
• Connect the video output of the workstation to the Server Control Switch video input connector using an
appropriate cable/converter for connector and sync conversion
• Connect and power on the rest of the Server Control Switch system per the appropriate installation instructions.
4. Technical notes
Keyboard
The Type 5C Keyboard to USB Adapter emulates a Sun Type 6 USB keyboard (P/N 3201273-01) and a Sun
Crossbow USB mouse (P/N 3703632-01). The Type 5C and Type 6 keyboards match in available keys, however
several keys are relocated on the Type 6 keyboard. The adapter appropriately maps the key codes generated to the
key legends on the keyboard (i.e. all keys work the way they are labeled).
TYPE 5C KEYBOARD TO USB ADAPTER Page 3
Important Note Regarding Standby Operation:
USB supports a SUSPEND/RESUME capability that has various and incompatible implementations across differing
hardware platforms. This can affect the operation of the adapter if the workstation supports a low power or standby
mode with an incompatible implementation. Low power or standby mode is normally activated through a menu
selection (using the mouse) or by pressing the POWER key on the keyboard (upper rightmost key on both the Type
5C and Type 6 USB keyboards). For this reason, the POWER key on the Type 5C keyboard IS DISABLED when
using the adapter. In addition, it is important not to activate low power or standby mode through other means.
WHEN IN LOW POWER OR STANDBY MODE THE SYSTEM MAY NOT WAKE UP THROUGH
KEYBOARD OR MOUSE ACTIVITY, REQUIRING A HARD POWER-DOWN TO RECOVER.
In addition, the POWER key on the Type 5C keyboard does not have the capability to power-on a system as it
would when connected to a Type 5C compatible workstation (nor does a Type 6 USB keyboard have this capability
when connected to a USB workstation).
5. Part numbers and Accessories
5188 Type 5C Keyboard to USB Adapter
4021 Cable, USB Type A/B, M/M 0.5M
4022 Cable, USB Type A/B, M/M 1M
4023 Cable, USB Type A/B, M/M 2M
4024 Cable, USB Type A/B, M/M 3M
4025 Cable, USB Type A/B, M/M 4.6M
Jul 10, 2009 | HP Multimedia Cordless Keyboard/Mouse...
Usb cord, I lost it.
What is the type of USB cable that you need? Is it type A to mini B or type A to micro B?
Here, I provided you the link where you can see the different types of USB cables:
http://www.outletpc.com/cables-usb-cables.html
I hope this would help.
Have a great day!
Best regards,
firesnake
May 27, 2009 | SanDisk Sansa m230 MP3 Player
Activate USBs on monitor
USB slots on a monitor act as a USB hub, and thus need a USB cable to connect from the monitor to the computer. Check the plug type on the monitor, if will either look likea normal USB plug in near the power and video cables or it might look a little more square; simply get a USB cable of this type (Type A for normal, type B for squarish) to connect from your monitor to a normal USB plug on your computer ( Normal being type A), and it should work.
Mar 12, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Canon MP370 All in one printer
Tou need standard usb cable :
USB Type A Male / Type B Male Cable, 2.0 Version, 1 ft
Power cable must be standard two prongs on printer side, and depends on your socket on other side.
You can find both cables at any local computer and electronic reseller.
Aug 28, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
HP PSC 750 All-In-One InkJet Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
