Question about RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Need IP address for this modem - RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
    President:
  • 2,992 Answers
The default IP for these is //192.168.100.1, I believe.
Posted on Oct 14, 2010
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
ZOOM V92 IP address
If you need to find the ip address of your modem then connect to your network(internet).And then open IP-Details.com here it display the ip address of your modem.
Feb 02, 2014 | Zoom (56K-V92) Modem
Why will it not connect to the internets IP address?
If you reset the modem and ip address will not change and remains same hence it is static ip address.If you reset the modem and the ip address change ,it is dynamic ip address.
You can get the Ip address from your internet service provider.you can check the ip address using the site Ip-details.com .
Jan 25, 2013 | RCA DCW615R Wireless/Cable Modem
Chaneg ip
There are two types of ip address available..One is static ip address it will not change forever...But another ip address is Dynamic ip address.It will change..If you need to change dynamic ip ,you can reset the modem it will assign new ip address for you...everytime you can reset the modem and get new ip address...It\'s possible only if you have dynamic ip...You can check whether your isp provided ip is static ip or dynamic ip by visiting the site IP-DETAILS.COM
Sep 15, 2012 | Computers & Internet
Hi. I have a Motorola SB 6121 DOCSIS 3.0 cable modem. When I have a direct connectivity with this modem to the laptop with an ethernet, it works fine. But when I connect it to the Linksys wireless router,...
what is the ip address of the cable modem ?
when connected directly to the modem can you do ipconfig in dos command window and find out the gateway ip address listed.
This has to be the gateway ip address in the wi fi router.
turn of DCHP server in the WI FI router and make its ip address one more than the cable modem ip address.
make sure subnet mask is the same in both devices
Make sure DHCP server in Modem has leases above 20 to allow other devices to use 1 - 19 .
eg 10.0.0.1 or 192.168.0.1 for cable modem ip address internally.
make wi fi router 10.0.0.2 or 192.168.0.2 depends on the ip address of modem ?
Gateway address of 10.0.0.1 or 192.168.0.1 depends on the ip address of modem ?
dhcp server leases from 10.0.0.21 to 10.0.0.254 depends on ip address of modem ?
Feb 22, 2018 | Computers & Internet
I have a lap top,i bought a router Q.how can i connect without lost the office internet line?
jromero608
To connect your router to your network with out losing your Internet connection will depend on what kind of modem your have. If you have a modem with a built in router in it you can connect it to one of the extra network ports on the modem.
However if your modem does not have a router built into it you will have to disconnect the modem for a short time to connect the router into the network.
Note if your have a modem with a router in it the best thing to do is let it keep assigning IP addresses and turn on the DHCP server in your router and use it just as wireless access point. To do this you will need to set it to the same IP group that you already have on your network. So example if your modem has an IP address of 192.168.5.1 you will want your router the routers IP address to 192.168.5.2. The third number section is what is important. If you do not currently know the IP address of your modem and it is connected directly to your computer the link below will help you determine the IP address of the modem. The IP address listed as the gateway IP address should be the IP address to your modem. Note if you already have a router in your network this will be its IP address.
http://www.fixya.com/support/r4935363-determine_computers_ip_address
If you need more help and/or have trouble getting everything setup let me know the make and model of your network devices and how you have them connected so I can see what we need to do to get you setup with your new router.
Issken
http://www.fixya.com/users/issken
Oct 06, 2010 | Computers & Internet
Cant connect to xbox live need an ip address how do i get one
When the SurfBoard modem is powered up and connects to the internet on the WAN interface, it automatically gets an IP address from your ISP. When another machine is powered up and is connected to the modem via a USB cable, it is automatically using the WAN IP address to communicate with the world. If it is connected via the Ethernet connection, the modem automatically issues it its own IP address for use on the internal network via DHCP. The modem's internal Ethernet connection is 192.168.0.1. The next machine powered on will normally get an IP address of 192.168.0.2.
May 30, 2009 | Arris SURFboard® SB5101 Cable Modem
I have to power cycle modem as I keep loosing IP address
Depending on the internet provider, most IP addresses are set for a certain amount of time before the lease on them is up, in most cases the modem automatically renews the lease and the modem keeps the same IP address. In some cases, when the lease expires, the modem receives a new IP address from your ISP's dhcp server. In rare cases, the modem does not receive an IP address due to either a failure in the hardware (of the modem, hence faulty modem, time to replace) or the firmware on the modem needs to be upgraded. To upgrade the firm ware on the modem, a call to your ISP's tech support should solve that.
Mar 24, 2009 | Cnet CWR-905 Wireless-N Router
How did i change the ip
Your internet service provider only able to change your external ip address. The only way to change it own by using proxy sites or ip hide software's. Online proxy sites are simple and free of cost . But they worked for some periods only. So you can always check your ip is hide or not at Ip-Details.com
some free online proxy sites
hidemyass.com
hidemyip.com
boomtunnel.org
anonymous.org
Jul 15, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Xoom x6 adsl modem problem
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
Oct 18, 2007 | Zoom X6 (5590) DSL Modem (55900003)
RCA DCM425 DIGITAL CABLE MODEM (RCADCM425) Logo
782 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
Jose Velazquez
Jose Velazquez
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
